3.0 V6 Vacuum Leak - IMT O-Rings?
Hello all,
Are there any audible symptoms for IMT O-RING Failure?
So engine (idle) with bonnet opened we hear the following...
If we repeatedly blip the throttle - a loud and very quick "suck" noise from the air-intake area is heard prior to RPM increase - pressure not balanced?
When engine is shut-off a 3-4 second a "hiss" followed by a sharp "squeak" is heard from the intake manifold area.
IMT O-Ring failure or is there a larger gasket we've over-looked?
Thanks for your time.
p.s. This issue was noticed after replacing a leaking coolant tank and checking engine with the bonnet open - we're not sure how long engine has been doing this or whether it's thanks to correcting the leaking coolant tank.
Have you seen this:
https://www.jaguarforums.com/forum/s...ck-pics-49214/
There will be oil on the paper towel and you can see burnt oil on the exhaust manifold cover. Also sometimes you smell burnt oil in the cabin.
I have responded to your PM.
Here is a link that will help you identify all vacuum lines, PLUS note the link to Gus's site for the elbow located under the lower intake manifold, its a known issue!
https://www.jaguarforums.com/forum/s...ics-faq-52720/
Received 6,320 Likes
I've read Just had another check whilst weather dry...
Hissing definitely coming from rearward of intake manifold - there are lots of hoses behind there...
See 3rd comment on this thread....
Jaguar S-Type Check Engine Light - Car Forums - Edmunds
I've checked IMT with towel - bone dry, no oil.
Thanks,
Thanks,
I am laughing at some of these guys: Jaguar S-Type Check Engine Light - Car Forums - Edmunds
Twit's![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Leonard, really we can go around and around here, so I am just going to come out and say it. Most likely the elbow under the lower intake needs replaced, I would rerplace it along with all the intake seals, plenum seals and vacuum lines, IMT O-rings. This should cost around $200.00 (US), sorry I am not into doing the conversion. If you can DIY it will take about 6~8 hours for the first timer....
Heed my advise and do it, then you can get along enjoying your vehicle!
Twit's
Quick update guys,
Thanks Jagv8, Rick and Gus for help,
Removed windscreen cowl and cross brace to thoroughly check behind intake manifold.
What I discovered, if done deliberately, is a DISGRACE. Someone (dodgy garage) has sabotaged this hose – see angled filing marks exposing internal tubing.
No small creature took fancy for its lunch and I don’t sleep-walk. It’s taken me weeks to discover this abomination.
What is the part, its importance and difficulty to replace?
The hose leaves rear of intake and divides – one tube travels to unit on PSide wheel arch, the other red inner-tube (sabotaged!) travels 6 inches to a fuel pressure regulator, if JTIS is correct.
p.s. JTIS method for 2000MY intake manifold removal seems incorrect, it displays several engine components my vehicle just doesn’t have, for example the EGR valve isn’t there!!
I'm guessin' that's a UK model without EGR like we have here in the States. That would mean the vacuum harness has one large elbow at the rear of the induction manifold, two hoses off that elbow, one going to the Injection Pressure Sensor, and one going off the engine to the LH side of the engine compartment to the Evap/Purge assembly; all in a corrugated wrap. Best I can tell that's part number XR811833. You might check along the length of that vacuum harness and see if there are any tags with weird numbers on them, something in a format similar to 4X83-14C293-AB. If you can find a number like that, the spares guy can likely use it to confirm the service part number.
Check with your dealer spares guy and see what he says.
Good luck!
Good luck!
Gus (08-17-2012)
