4.2 l V8R coolant leak
Hello,
Who could tell me about a problem with a major leak of engine coolant not running? Fluid is flowing backwards on each side of the gearbox and is not visible from above or below the engine. The car is 18 years old but only 80,000 kms. Thank you for your answers, explanatory photos welcome.
Regards,
Jean Michel
Regards,
Jean Michel
scuby (07-19-2020)
Thank you, the search was done with the endoscope but it did not find the origin of the leak. that's why I launched this call for "help", because as a last resort the mechanic suggests that I take out the engine.
Received 2,677 Likes
The following 2 users liked this post by NBCat:
Jean-Michel (07-18-2020),
kr98664 (07-18-2020)
There is no way to tell which hose gave without pulling the supercharger or intake, whichever the case may be....i am in the middle of such repair right now....both hoses will be replaced....once in a great while the 90 degree hose attached to the water rail will split and run down the valley and off the back of the engine
The following 2 users liked this post by scottjh9:
Coolant leak
good idea...order the 2 hoses under the intake and the 90 degree outlet hose i mentioned...the coolant hose to throttle body is found in the throttle body parts diagram...the coolant hose to egr is found in the egr diagram and the 90 big hose is found in engine cooling/water rail diagram....I use jaguarlandroverclassicparts.com for their diagrams or terrysjag
@Jean-Michel, since you're in France, you can also source parts from SNG Barratt France:
https://www.sngbarratt.com/Francais/...guage=Francais
NBCat
Best regards,
Coolant leak continuation and end
Ultimately after dismantling the admission and everything that goes with it, the culprit has been found (I will try to attach the photo). Apparently, this hose suffers a lot from the heat inside the V8. in addition to its replacement, it is planned to thermally insulate it to protect it. The parts were ordered from SNG Barratt
Have a lovely day everybody
Jean Michel
Jean Michel
kr98664 (07-20-2020)
kr98664 (07-21-2020)
Thank you for your valuable advice, as a reminder this is a 4.2 l V8R from November 2002. Do not worry all the surrounding parts are checked and replaced. The car benefited from a major overhaul with all fluids being changed, as well as the replacement of all the rear axle tie rods. The maintenance carried out is carried out with a collector's spirit, since it is parked in the garage with a Citroën Traction 11B from 1949, a Citroën DSuper 5 from 1973, a Citroën 2 CV6 from 1980 and a Motoguzzi California Titanium from 2003.
Best regards.
Jean Michel
Best regards.
Jean Michel
Sonspit
02-19-2015 10:26 AM
jmcGoBlue
03-05-2012 11:41 AM
