4.2 v8 s type
Received 2,263 Likes
The question is vague enough that I may have the wrong end of the stick.
>yes use the engine in a rod
Sorry, but that is a silly idea and wondering why you would ever consider it. Too many electrical components needed with a modern engine and it would be considerably expensive to try to engineer a solution.
Better to buy a GM crate engine.
Air, fuel, spark, bang, nothing else needed.
KISS...
Jaguar - it's not an automobile, it's a Motorcar
KISS...
As far as I know, not many Rodders or performance oriented ECU hackers have cared to hack and modify the programming of the ECU used in the S-type. (A few LS owners have played around with their ECUs)
One other thing these engines have that make it harder to run aftermarket engine control systems is "Variable Valve Timing" I believe there are a couple very expensive control systems available now, but you'de still have figure out the timing curves to run the engine correctly.
If you didn't have to deal with VVT, there are several good aftermarket engine control systems that you could use to run the engine.
I started thinking a bit, that since the poster's name is "DaimlerMK2" Perhaps he is looking into trying to swap a more modern AJ-V8 4.2 engine into an MK2 Jaguar. Interesting concept.
If this is his intent, I see a lot of challenges.
- If the engine fits in the engine compartment, next he'll have to figure out a transmission that will work in the car and mate it to the engine.
- If the engine fits, he'll have to fab and install all the peripheral support items. exhaust, fuel delivery system, drive shaft, mounts, air intake, engine oil cooler, trans cooler, radiator with cooling fan and perhaps secondary water pumps.
- Then he will have to figure out how and what he wants to do regarding the electrical: Aftermarket control system? Harness swaps? ECU programming?
With a 4.2, this will be the make/break for the conversion.....
Joe
Joe
>He might have got it VERY cheap. Maybe 100s GBP ($100s), which I imagine a crate engine would not be.
That may be but he is going to be faced with a very high cost (both money and time/frustration) in trying to do it.
Sell the 4.2, get a crate motor, and have at it.
Angle parked in a parallel universe
If I wanted to do something along these lines - as if! - I'd keep every item unless impossible - electrical, electronic, the lot. The whole set of multiple computer networks. Remove any that left it working, which may not be many modules but will be plenty of sensors and actuators (but no powertrain ones). I'd start with the 4.2 car and disconnect the ones that seemed highly likely to be unneeded (er, electric window motors, that kind of stuff). Get down to a large set all of which are needed whether desired or not.
Definitely going to be keeping all engine items and the trans. Probably GECM, ICM, RECM, FPM, etc, as well.
I'm not convinced it'd be wise but it'd be fun...
Can't say I'd want to go near a GM crate engine but hey others may like that.
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
KarimPA
09-27-2015 08:46 AM
Gerard Radimaker
09-13-2015 10:33 AM
