4.2l na to 4.2l supercharged
#63
This car was given to me as a wedding present brand new in 2004 from my parents so means a lot to me
The town i live in there are only 5 stypes 4 are v6s
the 4.2 v8 and the type R are very rear in New Zealand
I did find one engine in New Zealand used and was 10 k
Plus shipping
Bringing a used engine in from uk was around 9k to 11 k
Due to shipping costs and taxes and all the paperwork
Then you don't know what problems you could have
Example could get it and have low compression
Leaking headgaskets and so on
so would still have to strip down
At least i know all parts in my engine are brand new
And I'm not going to have any problems
Darrol
The following 2 users liked this post by Darrol2004:
S-Type Owner (06-11-2023),
User 42324 (06-12-2023)
#64
Plus shipping
Darrol
Plus shipping
Darrol
#65
Ok i found a 4.2 na same year as mine for $250 + ecu + harness. Did this before with the v6. Ill clone the immobilizer and voila.
question is, will the v6 version Zf6hp26 do well with the v8? The bell housing is different for once, and also the torque converter i think is different. What would be the worst case scenario? Could the torque converter get burned from the brutality of the v8(na)?
thanks a lot!
thanks a lot!
#66
I hate to tell you, but a Jaguar mechanic told me a long time ago that the internals and software of the transmissions are different for each engine. STR is different from NA V8 too. If you can get the trans that went with the motor you bought, it will probably work better and longer than a V6 one. It might be good to double check though.
elDariusVargas (06-19-2023)
#67
#68
To explain this in more detail: The MY engine has to be mated with a matched transmission. This is usually done via the VIN number series. It is not that the transmissions are physically/mechanically different, but that the control modules inside the transmissions are programmed to work the the programming of the ECM for a particular engine. (Shift points- combinations of rpm and torque that determine when the trans will up or downshift.
I am talking about the ZF 6HP26 transmission series.
Same transmission was used in all of these cars. The primary difference being the TCM/programming.
- 20012008 BMW 7 Series (E65)[3] 735i, 745i, 760i, 730d and 740d
- 20022005 Jaguar XK8/XKR (X100)[4]
- 20032012 Aston Martin DB9[5][6]
- 20032010 BMW 5 Series (E60)
- 20032010 BMW 6 Series (E63) (Pre-LCI models, 645i / 650i / 635d)
- 20092012 Hyundai Genesis Sedan (4.6L V8)
- 20032008 Jaguar S-Type
- 20032009 Jaguar XJ (X350)
- 20032012 Rolls-Royce Phantom
- 20052011 BMW 3 Series (E90, E92)
- 20052016 Ford Falcon (BF,[7] FG,[8] FG X turbocharged inline-six and V8)[2] Although production of the transmission ended in 2014, Ford retained sufficient inventory to last until end of Falcon production in 2016.[2]
- 20052014 Ford Territory (SY AWD;[9] SZ petrol)[10]
- 20062010 Jaguar XK/XKR (X150)
- 20072019 Maserati GranTurismo
- 20072012 Maserati Quattroporte
- 2007present Rolls-Royce Phantom Drophead Coupι
- 20082012 Aston Martin DBS V12[6]
- 20082012 BMW 7 Series (F01), except 740d xDrive, 760i/Li and Hybrid 7
- 20082011 Kia Mohave
- 20082012 Jaguar XF (X250)
- 20062009 Bentley Arnage
- 20082011 Bentley Brooklands
- 20102014 Aston Martin Rapide[6]
- 2011 Hyundai Equus
- 20112012 Aston Martin Virage
- 20122014 Aston Martin Vanquish
#69
Good post Tijoe, so many cool cars to click on, besides info. For the project, a full donor car is the way to go, if you have the space for it. You could even sell parts, at least in theory. If can have the right set up, it would be nice to leave the motor and trany together and put in as one piece.
Javaldo
05-16-2019 07:13 PM
McJaguar
03-05-2013 08:36 PM
