42 Miles until empty, but out of gas!
I ran out of gas today... been a long time since that has happened to me :-\
The fuel gauge was above the empty or red zone, and the digital readout on the speedo said 42 miles until empty. How can that happen?
Any idea what needs to be checked? Thanks!
First question... How much fuel did it take to fill it?
On my 3.0 it will say less than 10 miles to empty then take a tad over 15 gallons to fill a 18+ gallon tank. That is by design, according to the dealer and sources here. The fuel pump (in your case pumps) uses fuel for cooling, therefore running dry can overheat the pump(s). Is your 06 still under warranty? I wonder if the float stuck? Causing the gage to think you still had fuel. One positive, if you do have to service the main fuel pump or the secondary pump they are real easy to get to. Just pop out the rear seat cushion and there are access panels right in the floor.
Not much consolation for you but I've run my 2004 STR pretty low and it WAS into the red and indeed down to range 15 miles (which was why I chickened out). However, it had been more like 50-something when I'd last turned the engine off. I'd then parked overnight and restarted, driven a couple of miles and the range absolutely plummeted (different type of roads, much slower speed).
The STR has an extra pump and control module (see the wiring diagrams) so you have 2 pumps which MAY have overheated (but probably haven't). Unless you want to remove things to check, it's hard to be sure whether it's actually out of fuel as opposed to just not pumping it out. In the second case, you'd be looking for a problem with it not getting the fuel out (such as pump overheating and shutting down?), in the other case it probably would have to be the level sensor. If that's cheap and easy to replace I'd go for that. Pumps will likely not be cheap.
When I filled it up, it took 18.83 gallons. I think that is more than the published capacity...
Are the fuel gauge and the unit that calculates the "miles until empty" fed by the same component?
The car is under warranty still (CPO), so I'll ask the dealer to figure it out. Now I just need to find the time to let them work on it...
Seems like a lot of variation?? My 2005 STR will go to zero miles and I have never put over 15.5 gallons in it. So I regularly run it to zero miles left plus a bit more. My old SHO also wanted you to fill up in the 15 gallon range. It also had a 18+ gallon tank.
Published size for the S Type is 18.6 gallons I think.
The light never came on, and I never heard any audible chimes (I think I read somewhere that there was supposed to be one). Even after the car died, the light didn't come on.
The computerized "distance to empty" varies so widely from car to car and even from current road conditions, driving style, etc. Plus, when you drive it to nearly empty your pumps are pulling the dirtiest gas in the tank (impurities, sediment, etc. become more of a factor as your tank level drops to almost empty). Why take a chance? Fill that sucker up when your gauge drops to a quarter tank remaining. That's my philosophy. But I can never get my wife to follow that rule - she'll drive home with the light on and expect me to run out and fill it up for her....
These cars are calibrated to keep a few gallons on reserve, so, Bull, you should be OK running it down to close to zero. Then again, if the float sticks....well that is another issue and how would you know?
I am 99% positive I get a chime. Josworth is correct, if that floater got stuck, thats the reason. I actually thought that there were electronic sensors judging the amount of gas in the tank and no floater. Lear something new every day.
I think they are acurate to a point but not 100%.
Take a look next time you get home on what its says is left and then in the morning when you leave take another look after it recalibrates itself. Those two numbers are never the same, ours is usually lower,sometimes by quite a bit.
My other vehicles with the same system also do this. My point is that mabe they(all vehicles) tend to have brain farts as we drive. Once is is stopped and allowed to "catch up" it might give a more accurate read.
Just an observation by me. Give it a look and see what yours does.
Not only do you get a chime but the NAV screen lights up with a LOW PETROL warning and lists all the locations nearby so you can pickup gas, that is if you have NAV.
I ran mine to zero once, which I normally don't like doing because I was in Beverly Hills, and they charge like 1 buck more for gas cause you are IN Beverly Hills.
So it ran to zero miles but I made it about another 12 home to my local gas station.
I bet the dealer figures this out in no time.
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Originally Posted by MyBlackCat:
"Take a look next time you get home on what its says is left and then in the morning when you leave take another look after it recalibrates itself. Those two numbers are never the same, ours is usually lower,sometimes by quite a bit."
Thanks for all of the good info folks! I'll see what solution the dealer comes up with now...
I just pulled a receipt out of my wallet from today... DTE said 66 miles this morning..I remember that... I filled up a mile from my house and got 12.861 gallons. The computer says my average MPG is 20.8...
66/20.8=3.17 add that to the 12.861 and that is 16.031...add in the 1.4 reserve and that only adds up to 17.431.... Where is the other gallon??
OK back to work....
Now there can be at least a 10mpg difference between highway and city driving, especially in overdrive etc. The next morning when you start the car the trip resets. You back out of your driveway and start heading 25-30 mph on local roads, it knows how much gas it has left (besides the reserve that you aren't supposed to get into) and recalculates based on the slow city speed (or your average mpg). Until you develop a history with this trip.
The more fuel you have onboard - the greater the potential discrepancy in miles. 15 gallons on the highway will take your 150 miles give or take more than than the same 15 miles burned in the city.
Oh and Jeff... This would also prob explain your DTE figure being off. Were you driving stop and go or slowly? That 66 miles was prob calculated over 4 or so gallons of fuel. Plus I think the computer thinks zero = 2.5 gals aboard. Under 1 gallon = potential overheating of the pumps, so while the reserve is "1.5" gallons, I think there trying to hide a gallon to save the fuel pumps.
As to the OP taking on 18.83 gallons after running the car bone dry. Does the filler neck count as fuel capacity? If it's an 18.5 gallon tank you could easily be holding 1/3 of a gallon in the filler neck. Especially if you get a gas attendant that's trying to round up the total to the next dollar..
George
