5R55N autobox delay in selecting Drive
Old 09-13-2018, 06:01 PM
Received 2,665 Likes on 1,829 Posts
It is possible there is a pressure issue with the pump. Did you check the line pressure?
When the gearbox is engaged, the pressure should rise to between 7.6 and 18.1 bar (110 and 263 PSI) in Drive and to between 9.7 and 24.1 bar (140 and 350 PSI) in Reverse.
Old 09-14-2018, 06:05 AM
wheelerc's Avatar
I didn't check the pressure (I don't have the tools/knowledge to do that). Am I right in saying if the pressure is low the box will need to come out to check the pump and replace the pressure control valve?
Old 09-14-2018, 08:57 AM
If the pump is faulty, the gearbox must be removed to change it. The pressure can be checked with the gearbox in situ as the fittings for line and control pressures are on the sides.
wheelerc (09-14-2018)
Old 09-14-2018, 09:04 AM
wheelerc's Avatar
Thanks, is there a guide somewhere on how to do this for an amateur like me?
I can see where the fittings are from the manual you linked to previously, and the pressure range, but I'm not sure what equipment I'd need and how to connect/test...
Old 09-14-2018, 09:12 AM
Here's one for thirty quid:
https://www.ebay.co.uk/itm/Automatic...QAAOSwGMFbcpGA
The correct thread connector must be fitted to the gearbox and then install the gauge. Probably best to have one of your mates handy to start/stop the engine.
Old 09-14-2018, 09:18 AM
You may be able to find the procedure on YouTube. For example:
99xk8guy
05-28-2024 09:36 PM
Skeeter
09-17-2015 08:15 PM
JimMLiny
09-09-2015 08:13 PM
Xkr x100
09-06-2015 08:50 AM
XJsc-guy
09-02-2015 11:43 AM
Quick Reply: 5R55N autobox delay in selecting Drive
