5R55N Fill Plug?
It's on the BACK (REAR) of the gearbox next to the propshaft output.
The writing on the rear cover says something like "check level between 30 and 50 degrees C".
It is the only 8mm plug on the back of the box.
The level plug is the 5mm or TORX (depending on if/when it was replaced) in the bottom of the pan.
The LARGE hex is held while the small plug is removed.
The whole thing can be removed to DRAIN the gearbox or get the small plug out if the 'locktite' won't budge.
I keep a spare in case the 5mm plug strips and won't come out.
bob gauff
bob gauff
This is what I use to fill transmissions, transfer boxes and differentials on various cars. They are always hard to reach but a garden sprayer, with the atomiser nozzle removed, gives a nice, easy way to do it. Fill with fluid, pressurise the sprayer and then lie down and spray ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/87799-5r55n-fill-plug-dscf1824.jpg?dateline=1402737700)
The second picture shows where the filler plug is:
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/87800-5r55n-fill-plug-dscf1826.jpg?dateline=1402737700)
The following 2 users liked this post by clubairth1:
magmedia (06-16-2014),
motorcarman (06-15-2014)
chatmanx
09-11-2015 07:17 PM
