About to give up....
#62
Well, that's the first step in getting to the bottom of your issue. No, the induction system should not be in that state. That means part of your airbox is missing, and you are most likely running on hot air from the engine compartment instead of the cool air from in front of the car. Bad news, that just adds heat to an intake system that CAN'T be cooled enough as it is.
The next thing we need to know is, what is the engine temp at the time you experience the noise and power loss. If you only have a code reader, that means we'll probably have to leave that for a possible trip here to Indy.
After that, let's look into the intercooler coolant pump. That is what circulates coolant through your charge air coolers on either side of the supercharger. That pump is located to the right [passenger] side of the radiator and slightly in front. It should run ANY time the ignition is on. It is powered through fuse F36 [15 amp] in the front fuse/relay box behind the RH headlamp. If it does not run, more bad news; that means the charge air is running at the full temp of compression by the supercharger. That will usually cause terrible spark knock and a host of other possibly harmful things. It could explain the falling on it's face when accelerating.
That car has a pretty light history with Jaguar for it's first 50,000 miles, and I know there is a software update that was put out several years ago to address a spark knock condition in the early STR's. I can find no evidence it has ever been done to your car. Whatever the case, we should at some point take care of that.
So there's a little for you to go on to start with. For now, I'd forget about the supercharger itself and it's belt. The above is more important to investigate first. You look into what you can; for what you can't, we can work on scheduling a trip to Indianapolis.
Good luck! I'll be standing by........
#63
#64
How would I go about checking that?
#65
Attached is the fill & bleed procedure; during it you should be able to tell if the pump is producing.
Cheers,
#66
I just had the coolant expansion tank replaced; I assume this procedure would have had to be done?
#68
#69
I'm glad you weren't offended!
I believe the coolant pump runs as soon as the ignition is on so the coolant should circulate all the time as the engine warms up. You may be able to feel hoses and check they warm up consistent with the coolant properly circulating, though access can be "tight" (as in: very). Stay safe, though - remember moving parts especially those that may start suddenly, such as the radiator fans.
JTIS shows the cooling circuits (the Technical Guides may actually be better). On the STR there are really 2: one with the engine-driven water pump and the other with the electric coolant pump mentioned here. They share the single expansion (header) tank. Both can need bleeding.
#70
#73
The Chris X (08-15-2011)
#74
I am still looking for an intake. The problem exists when it is 65 degrees or 95 degrees, with a cold engine or a normal operating temp engine, so I am inclined (notice I didn't say assume ;-) ) to believe the air intake is not the cause and it worked fine for a couple months. All of these problems cropped up when I had the oil leak and subsequent misfires referred to in a previous post. after those problems were taken care of, these problems just showed up...
#76
#77
#79
Found this on eBay and would like someone to confirm whether this is the correct part to replace the PepBoys "cold air" intake the previous owner installed and whether or not I would need anything additional (hoses, clamps, etc.).
2005 JAGUAR S TYPE AIR CLEANER | eBay
Thanks,
Joshua
Thanks,
Joshua
#80
Thanks,
Joshua
Thanks,
Joshua
Cheers,
