About to sell my "03" S-Type
I'm about to put my S-Type up for sale but have an issue that I want to correct before listing it. During (only) cold days on cold starts it missfires on (codes thrown for) cylinders 1,3,5 for with the code for multiple cylinder missfires, Restricted performance and CEL read in the instrument cluster. I'm thinking intake gasket leak but wanted to get some professional advice before throwing time and money at the problem.
Does the car still have its yellow-colored factory Intake Manifold Tuner Valve O-rings? If so, that is often the problem. They fail, leak oil, and create a vacuum leak. The new-and-improved green-colored O-rings solve the problem, and are quite inexpensive. You'll need a set of two....
Search using the phrase "IMT O-rings replacement" and read all about it, including how and where to check for the oil leak. You can do this repair yourself with minimum tools. It seems that anyone with the 3-litre V6 engine eventually has to do it....
DavidRey (11-18-2011)
Have you pulled the plugs to see if there is any oil on them? I had to have the spark plug O-rings replaced for this.
I doubt it because I replaced those not even a year ago, Havent had time to do the IMT valve seals just have it sitting in the garage for now, I did find that the rectangular thing on my intake pipe had a tear where they are conjoined, sealed it up with some gasket maker, might have been the cause of the rough idle that I've had maybe even the misfires but havent tests driven it yet, will report back with the results.
FS[SouthWest]: 21" TSW Nurburgring wheels with Tires
jorgef858
11-30-2015 04:24 PM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
