ABS DSC wheel speed harness SAVED some $$$
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
Hi to all my forum members. I just recently had some ABS and DSC issues with the passenger rear wheel speed harness. The harness was bad so I need to get a new one for my VIN. Rang the harness was about $250 a side for a 03 m6 VIN. So I saw the VIN. Of n52048 to n78757 are going for about $20 each I said I will try it and see if they work if not only wasted $40. So I got the new harness and they are different, ***BUT*** you can make them work the end that connects to the wheel speed sensor looks like it won’t work but it does. It slides over and locks down on it. The other connector that connects to the body harness is different but you can use the old connector from the old harness you just have to take them apart and use the old connector on to the new harness its was not to bad to do.
I had the ABS and DSC light come on and off all the time for the last couple of months. I changed it out last week with this fix and works great and save about $460 bucks. Just wanted to let my fellow forum members know, you can save some money. The part numbers I used are XR854747 for right side and XR851987 for the left side.
Thang Nguyen
10-12-2015 01:25 AM
innzane
09-02-2015 10:08 AM
