abs fault and dsc not available
These modern jaguars do not like being left alone for such a time. You may find that the battery requires a full charge. Depending on how long the battery has been with the car, you may need a new one.
Cheapest fix, fully charge the battery and then keep an eye on it.
Top tip, if you do have to leave the car for standing for a long time, switch everything off in the car and then double lock it on the remote. This will basically put the car to sleep and drastically reduce the current drain on the battery.
Hope this helps.
Hope this helps.
goges
10-05-2015 04:53 PM
