ABS Fault indicator and more.
My 2003 S-Type recently displayed "ABS Fault - DSC not available, so I took it to my local dealer. He said the nearside rear ABS drive-shaft had rusted through and broken, so he replaced it.
I got the car back and drove it for 20 miles where it was fine, but when I pulled away from a roundabout, I noticed some juddering, then the engine management indicator came on, followed by Parkbrake fault, then ABS fault again. After a further couple of miles, the speedo dropped to zero where it stayed for the rest of the journey.
When I got home, I switched off the ignition and restarted the engine. The speedo then worked OK again but the ABS fault indicator was still on. What's going on?
I would have the battery load tested to be 100% sure.
ericjansen
12-19-2021 12:20 AM
driver safz
09-26-2015 06:01 AM
xjrjag
09-24-2015 10:08 PM
