ABS scanner tool recomendations ..
hey guys as I stated in other thread I have purchased a AUTEL maxidiag MD808 PRO thinking I would be able to use it on a Porsche 01' , 03 volvo c70 my son's car and the jag stype guess what !! it don't work on jags stype 2005 . Im down to the ABS light wanting to pull those codes
after spending over $200 on the MD808 I really don't want to spend more than 100 more on ABS scanner
any recommendations ?? what can I get the will work
gracias---
gracias---
jaimster (10-24-2019)
gracias---
gracias---
https://www.jaguarforums.com/forum/market/224634
In my opinion by far the best system is to use the Jaguar SDD (v130) software and dedicated adapter like a mongoose.
However, this can be a bit daunting to use if you have never used it before.
You will need to set this up on a Windows XP pc or laptop that has no internet connection and that re-sets the date each time it is turned on.
There are virtual machine images available for free on-line that do all this for you.
You will also need a stabilised power supply connected to the battery that is powerful enough to run all the cars electrics without allowing the battery voltage to drop. As if the battery voltage drops too low the programming will be interrupted and may cause damage to the cars control units.
Mellow
Mellow
hey guys I did get the Icarsoft scanner works great ---- the right ABS sensor was bad, I got the right side wheel hub bearing with abs sensor from detroitaxle.com
about 53.00 it worked great replaced already and also both steering tie rod ends from autohauz they were bad car is starting to come along pretty nice...
no check engine lights at all now
NEXT ; need to replace powering steering fluid and transmission oil filter
S-Type Owner (11-03-2019)
