ABS & Traction Control Fault on a 2002 S Type, 3.0
Here is another thread on the subject:
https://www.jaguarforums.com/forum/s...+control+fault
In this case it was a wheel bearing. Following up with Jon's comments, after checking the obvious, try cleaning out the sensors.
Good luck,
Mike
Good luck,
Mike
Update:
took the car by the shop yesterday and discovered that both front bearings were toast. also found that the two rear sensors were beginning to crack as well.
front wheel hub assemblies were about 450 for both . rear sensors were 286 each (ouch). i elected to go with the front assemblies and HOPE that solved the problem.
just received a call from the shop and the car is done. front hub assemblies fixed the problem, and it's good to go.
tks for the input.
tks for the input.
Received 6,330 Likes
