abs traction control fault warnings
hi
need advice before splashing out on new parts. the traction control fault warning message came on and the abs light.i cleaned the sensors and the conections.still the same.i had problems reading the codes with the reader we used but c1235 u1262 j1850 came up.i checked the sensors with a metre got a higher reading on the drivers rear .i was going to start with changing that sensor first . what do you guys think s type 3.0 year 2000
cheers
dave
cornwall uk
cheers
dave
cornwall uk
J1850 is a comms standard for OBD, not a code.
Usually your type of issues are a sign of bad power such as failing battery or poor wires/connections, but possibly water/damp in the trunk (remove spare and look very very thoroughly).
But it could be the RH rear wheel sensor, of course. Your different reading supports that. Often "rust" type debris on it so it may clean. Yours would more likely be a bad connection or failed sensor I think.
dave w (07-24-2012)
