AC Blows Hot Air Only, Problem Found Need Help
On my 2005 3.0 Stype the AC was only blowing warn air. After much research and troubleshooting determined the DCCV was the problem. So, replaced the DCCV then looked at my CCM for burn traces on the board and had none. Still did not work. Finally, isolated an open on the DCCV centre wire and removed for repair. However, the wire was broken so close to the pin I couldn't solder.
Therefore, is it possible to get a new connector to dress it onto the old harness cluster? Or, do I need to buy the whole assembly?
Received 6,325 Likes
Ford makes pigtail connector kits for their cars and as the Lincoln uses the same valve there is probably one available.
Look here Motorcraft® Wiring Sets for Ford, Lincoln and Mercury Vehicles | The Official Ford Parts Site | FordParts.com
Jumpin' Jag Flash (08-25-2014)
Dccv
Barbara
Pins in most connectors are held in by little springy bits (tangs). Find an old one and have a play. Poke some strong thin metal item in - a needle or the like. If need be smash plastic to see what the pins are like to get the idea.
The big PCM-type ones are different because they're big enough to have a release mechanism. Once figured out you can do anything (move pins around etc) and re-lock.
BrentGardner
28
04-26-2024 03:08 AM
X_Type_South_Africa
12-09-2015 05:37 PM
