AC low side line at 73 lbs. preasure
#41
#42
Tom, I am deleting the "copy and paste" from another popular diy site, in your last 2 posts to this thread. They only add to the confusion.
In the previous photos of the 2 compressors side by side. The compressor with the black panel is an "old" style compressor according to Brutal. There is a TSB out about that "type" of compressor that was put on the 3.0 S Types and some X Types.
According to the PDF you can remove the "micro filter" cleaning then reinstall backwards, vacuum down system and charge.
The picture of the "new" comressor does not contain the plunge valve or micro filter.
Look here:
JTB00183NAS1[1] AC Valve.pdf
Look here:
![](https://www.jaguarforums.com/forum/images/kirsch/attach/pdf.gif)
#43
Look here:
Look here:
I have attached the file in question as a pdf and that I assume will not get changed. AllData sounds like Microsoft.
Tom
in Dallas
2005 Jag S-Type 3.0 58K
#44
Received 6,310 Likes
#45
Norri is correct. You do not use the black cover plate on the "new" style compressors. If you look at the pictures, the new compressor is on the left and the micro filter and plunger valve holes are cast sealed.
The ebay link I have does not work any longer and I cannot remember the seller. I just looked on ebay but did not find an OEM new compressor.
edit: I found the ebay seller that Norri and I purchased from, lasolas2020
Contact them directly through ebay, they had some great pricing on OEM!
Wolfy
05-28-2024 08:06 AM
Aus V8S
11-13-2015 11:01 AM
