AC not cooling at idle or low speeds
I live in a very hot climate - usually around 90 to 100 degrees daily during the summer month. The AC in my 2006 S-Type, V6, has been up to the task lately. It barely cools at idle or slow speeds, but does much better at highway speed.
Been doing an awful lot research and study and know the following things can cause this problem:
1. Fan for radiator/condenser not working at idle.
2. Condenser is clogged with bugs, debris and blocking air flow.
3. Freon levels too low and even too high and compressor kicks off at idle.
4. Compressor not operating at capacity at low speeds or idle. Or may be seizing up at idle.
4. Faulty expansion valve
5. Also seems to cool better when the inside of the car is cool, such as parking in a parking garage all day versus outside surface lot parking, Could the "Inside Temp Sensors" be faulty (very difficult to access on this car).
So I'm starting with the fan, which I verify that it is working, as i can see the blades spin down after turning the engine off. But it never runs after the engine is cut off. I also think it might have variable speeds and I don't know if the low speed operation is sufficient.
But does the 06 S-Type on depend on that single fan to provide cooling for the radiator and the "condenser" which is in front of the radiator. I don't see how any adequate air flow from that single fan could pass through the radiator and reach the condenser at idle. Or am I missing a set of electric fans for the condenser, as I did buy the car used several years ago.
At highway speed, I imagine there is enough air coming through the grille to cool the condenser and turn the hot freon gases into a liquid for cooling.
As for other possible causes, I had the DCCV (heater valve) and Climate Control Module replaced about three years ago. Surely the parts will last longer.
I see the "hot AC air at idle" is a common problem not just in just Jaguars, but other cars as well. And no one seems to have a good solution, so lots of drivers just live with it and hope the traffic light is not too long. I feel their pain, or heat!
Any thoughts or insight would be appreciated.
Earnest
Hot in the deep South.
Earnest
Dear Sweaty Earnest,
A tip of my orthopedic hat for thinking this one through and/or overanalyzing the problem. I thought I was the only one who did that...
What does your exterior thermometer read? If out of whack, this can affect the automatic control system.
Have you put the system in manual mode? Drive the temp setting down until it reads LO. That bypasses most of the automatic controls. This is great for troubleshooting.
I don't think your DCCV is at fault because you'd be getting even more heat at higher RPM. The heater isn't very efficient at low RPM, so you'd get less heat at a stoplight, not more. You can verify this with a thermometer in the center outlet duct. If warmer than the ambient air, the DCCV is adding heat, whether inadvertently commanded or if just stuck open. If the outlet air only reaches ambient temps, then no heat is being added.
Based on your scenario, here are the three most likely causes, in no particular order:
1) Low refrigerant
2) Low refrigerant
3) Low refrigerant
This is based on the assumption that the AC has worked well in the past, and it's been a while since the system was last serviced. Refrigerant will slowly leak from even the tightest system. If it's been at least three years since the last service, I personally would go straight to that. Your symptoms match exactly what my '02 does if the refrigerant is a little low.
Before you ask, gauge readings can NOT tell you the quantity of refrigerant. Gauges can help decipher compressor performance and things like that, but can't really confirm if the correct level of refrigerant is present. The only way to know is do a full evac and recharge with a measured amount.
Evac and recharge is the official party line. With that said, on a system that is providing at least some cooling, I've added small amounts and watched carefully for an improvement. The hard part is actually stopping if no improvement is noted, because the problem lies elsewhere. But if it's been several years since the last measured recharge, I can practically guarantee at least a small amount has leaked out. With reasonable safety against overfilling because of that, you can add three or four ounces and see what happens. Remember, if no improvement, stop. Don't just keep adding more because that won't help.
If you're not sure about adding a little refrigerant, you can always do the full evac/recharge instead and know for sure.
There's a tech bulletin about a spring in the compressor, or something like that. That's another possibility, but I think the symptoms are the same as low refrigerant. With the same symptoms, I'd probably shoot first for the more common scenario of needing refrigerant and see what happens.
1) Low refrigerant
2) Low refrigerant
3) Low refrigerant
Kyuss73 (03-03-2022)
Received 2,673 Likes
+1 on having the refrigerant level checked by a competent air conditioning specialist. Since the refrigerant is added by weight, there is special equipment needed to accomplish this correctly.
The system should not lose refrigerant under normal conditions, so you must check for leaks. Fittings can leak at their o-rings over time, so they should be replaced as part of servicing the climate control system. If refrigerant is leaking from the compressor seals, the compressor unit and dessicant/dryer should be replaced and the system evacuated and recharged with the correct amount of refrigerant.
In the meantime, reverse flush the condenser and radiator with a garden hose to remove debris clogging the air flow. This can help with returning the refrigerant to a liquid state. As you noted, there is only one fan for cooling the engine and pulling air through the condenser. If the fan continues to run when the engine is turned off, the thermostat may need to be replaced. The fan should begin to run when the air conditioning compressor is engaged, even at an idle. If not, check the electrical circuit beginning with the fuses.
Thanks guys for the replies.
As my "hot at idle" mystery continues, here a report on my commute to work this morning. I park under a carport at home, so the interior was relatively cool as I begin my journey:
At startup
Outside temp: 79 (based on dash display; verified by my outside thermometer)
Inside Car: 80
Commute to Office (Interstate highway, 70 mph)
Outside temp: 85
Inside Car: 40 (AC working well at highway speeds)
Arrive at work
Outside temp: 85
Inside Car: 50 (encountered a few stop lights after exiting interstate)
So as the outside temperature rises, the AC becomes less efficient, but still comfortable at highway speeds, until a stop at a traffic light. But should I have to run an errand at, let's say, mid-afternoon, when the inside car temp will be around 100, I'll be hot until I can get on the Interstate and get up to higher RPMs.
I will have the freon levels checked next week. In the meantime, I need to travel only on the Interstate, stay off city streets and only travel in the early mornings : )
The life of a Jag owner is never dull.
Earnest
At startup
Inside Car: 80
Outside temp: 85
Arrive at work
Outside temp: 85
Earnest
abonano (07-22-2016)
One more suspect I forgot to mention:
The compressor clutch could be slipping. If so, that can also cause poor performance at low RPM, but with adequate cooling at higher speeds.
This happened on my '02. It was caused by arcing and pitting inside relay #8 in the front power distribution box. This extra resistance decreased the voltage reaching the compressor coil and caused slippage.
I swapped relay #8 and relay #11 (fog lamps) for troubleshooting and got full cooling back.
Wiring diagrams here, courtesy of Gus:
http://jagrepair.com/images/AutoRepa...cal-2006on.pdf
Details are in figures 3.2 and 8.1
Warspite (07-23-2016)
At startup
Inside Car: 80
Outside temp: 85
Arrive at work
Outside temp: 85
Earnest
At startup
Inside Car: 80
Outside temp: 85
Arrive at work
Outside temp: 85
Earnest
Earnest
Earnest
Tom in Dallas/Plano
05 S-type 3.0 92k
Tom in Dallas/Plano
Location: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
A new o-ring cost me $15, additional parts and labor were approx $100; so the entire cost of the procedure was nowhere near the cost of purchasing and installing a new compressor & dryer (roughly $500). To me, trying the less expensive alternative recommended by Jaguar was a no-brainer.
Modifying your compressor valve spring might resolve your problem as it did mine, and at a much lower cost than replacing the whole shebang. The important things to ascertain first are that your system has the correct refrigerant level and that it is functioning properly in all other respects.
ampiko (08-08-2023)
My indie modified the valve/spring per the TSB instructions and it made a HUGE difference in the performance of my 2001 S-Type A/C, esp at idle and stop 'n go driving. That car is now tooling around hot and humid Miami Florida. Its A/C works like a champ.
Attached is the TSB
Tom in Dallas/Plano
Tom
Received 6,334 Likes
Jumpin' Jag Flash (08-07-2016)
Thanks a bunch.
Tom
jazzwineman (08-07-2016)
Ac resolution
At startup
Inside Car: 80
Outside temp: 85
Arrive at work
Outside temp: 85
Earnest
At startup
Inside Car: 80
Outside temp: 85
Arrive at work
Outside temp: 85
Earnest
I would suggest starting a new thread with your query, rather than hope this one ever gets resolved. In the meantime, work through this troubleshooting guide:
Everything You Ever Wanted to Know About the HVAC System But Were Afraid to Ask
Specifically, work through post #2 to verify the Dual Climate Control Valve is operating properly. A fault here (VERY common) can mimic an AC problem. Next, determine if your problem happens in Auto mode only, or Auto and Manual. If okay in manual mode, work through post #3. Otherwise, see post #4.
The following 3 users liked this post by kr98664:
