AC Questions 2006 S-Type 3.0
Sorry if this has been on the forums dozens of times, I tried searching but didnt find a specific answer. IF anyone can link me the solution or has an opinion I would appreciate it.
My ac blows outside air temperature air, so i thought to recharge the ac. Put the gauge on the low pressure side and was getting 45 psi. This was with engine on and AC on max. I do hear the compressor turn on and off when I turn AC on and off, so I think its working. Any thoughts?
This is about the best info on you climate control on the forum for the S-Type:
https://www.jaguarforums.com/forum/s...ol-how-185002/
Tom in Dallas/Plano
TBB
Even though you replaced your DCCV last year, check it again as detailed in post #2 in the guide.
After that, drive down the selected temperature until LO is displayed. This puts the system in manual mode and bypasses some of the sensors. This will provide some big clues for troubleshooting.
The 45 psi you’re seeing? That tells me you’ve got some cooling. The trick is determining if the system is physically capable of going cooler, or if a bad command is at fault.
Low refrigerant is a possibility, but I’m not 100% sold on that. Before you rush out and have it serviced, make sure the compressor clutch isn’t slipping. Details of a quick way to check are in the guide.
jazzwineman
04-21-2018 04:25 PM
Jbeau11
03-09-2015 03:49 PM
