actuator ventilation
Use the search bar and type in "an epic troubleshooting guide for climate control how to" written beautifully by kr98664....none better in any shop manual or how to forum...it is in the "how to" sticky...about half way down under the title stated above...good luck
Volker (07-18-2018)
Aw thanks, you're the best. $20, that's what we agreed, right? I'll get that to you right away...
Direct link to the troubleshooting guide:
https://www.jaguarforums.com/forum/s...ol-how-185002/
Volker, are you saying you can't switch the airflow between the dash, floor, and defrost ducts? Or are you just saying it's always warm? If always warm, the guide above will help isolate the fault.
What year is your car? That will help narrow down some details.
Courtesy of Gus, this guide shows the location of the door actuators on the '00-'02 models. Scroll down to page 3.4.18:
Jaguar Training Guide
Not sure about the later models, but the location is probably similar. Watch out because that guide covers more than just the S-Type, so not all information is applicable.
Volker (07-18-2018)
Volker,
The door actuators only change the source (fresh or recirc) and the exit point for the airflow. They have NO effect on the temperature. You may have two issues going on at the same time. Even if the door actuators are totally messed up and air is routed to the wrong location (floor, dash, or defrost), the air temperature should be correct.
Please read my troubleshooting guide (linked in previous post) to figure out the temperature problem. Specifically, see post #2 for details on how to test the DCCV.
For the door actuators, I deliberately didn't include much about them in the troubleshooting guide. Simply play with the buttons across the bottom of the control panel to manually select where the air is directed. If the airflow responds to the buttons and they don't make any excessive noise doing so, they are good.
Volker (07-19-2018)
itchyback
05-14-2017 08:54 AM
