adaptive shock tower crud
District7 (05-07-2017)
shock/damper tower crud problem solved! The yellow colored crud on the top of the shock/damper tower was coming from a worn out bump stop between the damper and the upper damper mount. replaced the mounts,bump stop, upper a arms and tie rod ends. huge improvement. Next up: stabilizer bushings and wheel alignment.
