Add front fog lights on S Type
![Post](https://www.jaguarforums.com/forum/images/icons/icon1.gif)
My S Type had been ordered as a dealer's show car. Therefore it has a few extras (e.g. Navigation) but other things are missing which I wouldn't even think they had to be ordered on extra charge - like an auto-dimming inside mirror...
Trying to get familiar with my car I noticed there is a lot of wiring in place for things never been added from the options list. Which shall mean the connectors are there, only the part is missing (e.g. the CD changer).
This being an introduction - the extra I am missing most are the front fog lamps. Does anyone know if the wiring is there - hidden somewhere? If yes - where?
The idea is to add some good aftermarket fog lights (LED; some claim to come even with original connectors), to get a used switch for the dashboard (plenty available), drill proper holes in the place where the original one's supposed to be - and all's set!
btw: anyone sceptic to this idea may speak up now or shut up forever...
tx
Martin
tx
Martin
hello @all,
thanks for your input. Under certain conditions (rainy night, fog, snow fall) fog lights give you a speed advantage of 15 - 25 kms against not having them - therefore I just don't want to give up that idea... May be that the originals have proven useless.
@V8: no there can't be oil coolers in that place straight under the head lamps. 1st the coolers are all centrally located behind the grille, 2nd oil coolers need vent openings (and there are none) and 3rd there have been oval fog lights on the 1st series models and round ones on the 2nd series. I'm sure Jaguar wouldn't have moved oil coolers around depending on which option you ordered... (sometimes their solutions are funny but don't think they'd be that weird ;-)
DukeOfStyria (04-10-2014)
the idea behind fog lights is they shine under the fog thus lighting the road where your regular lights just bounce of the fog and cause glare.
hello folks,
interesting posts so far - thanks.
Just to give you some more insight: most areas in Austria are mountaineous which means there are a lot of roads with just 2 lanes and winding up and down. If you have a rainy night drive you will have to go 30-50kms w/out foglights (approx 22-32 miles/hr), because you don't see exactly where the road ends on the sides. With fog lights you can - so you can drive a bit faster.
But I understand now JagV8's concern since I have seen Bad Cattitude's signature pic of an STR... - in my case those additional vents for the brake disk ventilation (I'd guess) are closed with blinds and on regular models that's the place for foglights.
DukeOfStyria (04-12-2014)
That's what I did today - getting down & dirty - the result you can see below. There ARE plugs in place for fog lights. Even in a nice little holder so they don't get dirty/wet - see attachment.
rgds,
Martin
rgds,
Martin
Bad Cattitude (04-12-2014)
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Quick update: yesterday I got the fog-lights I ordered from Adamesh UK. Went to the car, changed the switch to the one I arranged for already beforehand, plugged the lamps in - just to see if they would be working. The lamp on the dashboard indicates, they are on, but the lights themselves NOTHING - ?? ![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
Of course I did not give up right away (not my style), but tried the following:
- checked the fuses (the one for front fog lights is there and ok). Is there another maybe?
- changed the connection cables inside the fog light housing since it is suggested by the supplier because "some models use negative switching impulse".
- connected both lamps to see if maybe just one connector/lamp would be dead.
But I still did not get it working. Could it be that the use of the fog lamps needs to be activated by the dealer? (e.g. some software switch)
What I still need to check: if there is power on the wiring, but I need to see my neighbour for the right tools.
Meanwhile any usefull contribution welcome!
cheers
Martin
cheers
Martin
