Add front fog lights on S Type
but tx
M
ONEsicJAG (04-17-2014)
Front fog lights on 2008 S Type 2.7D
hello folks,
since alle my (3) girls where out of the house and the weather not too bad neither - I could fit my fog lamps onto the car finally.
And yes - I have checked with my friendly dealer - the 2008 model really never came with fog lights (even that the wiring was behind the blinds as discovered earlier). Which meant in conclusion - there would be no factory holders available - neither new nor used ones! So I decided to convert the blinds into holders for the lamps...
To make a long story short (~ 10 hrs):
The worst had been the cut-outs since the blinds are made from quite sturdy plastic and to get the polystyrene into proper shapes.
- I made a stencil how to make the cut-outs on the blinds.
- Then I fitted the fog lights.
- Next I filled the space around it with some polystyrene.
- Covered the polystyrene with fibre-glass and epoxy
- Painted the whole thing with modelling paint (spray) and filled a few holes with silicone - to prevent spray water getting inside.
2008 S Type with front fog lights
And now finally that's the result. In my opinion it looks pretty well. The critical ones may consider that I've never worked with fibre-glass/epoxy before.
Since the fog lamps have the same shape of the original ones (on the Mk II series) - I don't think the LEDs look worse than the original lamps had been.
"Quod erat demonstrandum"
A small note on the replacement lamps sold from Adamesh:
pros:
- they fit into the original place from the latter models
- they are "plug'n play" if your car had fog lights before
- for GBP 35,-- they are fairly cheap
cons :
- I had some "bad contact" issues when fitting them. Seems to work only in a certain position of the wires.
- I am still in doubt how the result will be when driving in bad weather conditions. But being said the original ones being useless - can't be worse neither
And here how it looks finally:
PS: no, I did not take the time to wash the car...
pros:
cons :
BrentGardner
28
04-26-2024 03:08 AM
Goncalo Proenca
09-08-2015 06:06 PM
stanjag
08-30-2015 10:35 AM
