Adjustable pedals not working
Yes all STR's had adjustable pedals and if you have long legs and put the adjustable pedals all the way forward towards the firewall they will break and lock up solid.
It's a well known problem due to the cheap plastic gear assembly as posted above.
I think heima has covered most of this in his post but attached is the instructions/explanations from the Lincoln LS side which of course suffers from the same problem. Might even be the same post?
It does look like Jaguar fixed this because my newer 2014 XJR does NOT have adjustable pedals and it has just about everything else possible!
I'm pretty sure my window sticker had a
"Cheap Plastic - STD equipment" line on it?
I'd be curious if that brass gear fix this issue though ... You know, in case my legs shrink.
Yes I would like to know how the brass gear works too. That is a great idea!
But unless your short I find most people just leave the pedals all the way forward.
It would be interesting to see if anyone had the pedals jam when they were NOT fully towards the firewall? The position of the pedals seems to be the major factor if they stick or not?
Feel I should clarify the Panther cars share the same gear, not the same pedal assembly...
Curless Auto
Hi
Would you have a link to where the brass gear can be purchased
or part number
thanks
Joe
Hi
or part number
thanks
Joe
Paypal: Mer@curlessautorepair.com $85 shipped in the Continental US. PLEASE include your correct shipping info and year make and model
#31
Hi
my gear was split, it can be removed by splitting the gearbox in situ, you need to grind the washer off that stop the gear coming off, once the washer is off, then the gear just screws off.
I temporary repaired the gear by closing the crack with a jubilee clip, and the melted the crack at the sides with a soldering iron
removed the jubilee clip and the gear was now in one piece, but has no real strength
I bought some mould making pouring rubber, put the gear inside a large aerosol cap and poured the mould rubber over it, once it set, pulled it out of the cap and then the old gear just pulled out, now I have a mould
I then found a steel washer the same size of the screw, split the washer so it would screw onto the gearbox spline just nice
I also put little holes in the washer all the way round for the resin/plastic to go through and give it better strength
I screwed the washer now into the mould so it was in he middle, then I mixed some 2 part plastic/resin, and poured it in the mould, you have to make a bent bit of wire and give it a quick stir inside the mould, this removes any bubbles on the upper side of the mould
15 minutes later and its set solid, with a steel washer insert for strength, just pull the rubber apart slightly and unscrew the gear, worked great on mine now for nearly 3 years
on my car the upper stop was not correctly set, it would try to drive through the end, hence the gear split, with jaguar IDS/SDD software and a mongoose lead you can set the upper and lower stops, so it stops before it runs out screw in the gearbox
cheers
Joe
a pic of mold and gears I made , left one had no steel washer inside, right one does, dont think it needs it though as it really strong plastic
https://www.dropbox.com/s/9glp9fegcy..._0380.JPG?dl=0
cheers
Joe
The following 2 users liked this post by Joedotcom:
Jumpin' Jag Flash (08-29-2017),
User 42324 (06-30-2020)
#32
Just out of curiosity, how much would it cost shipped to the uk
thanks
Joe
#33
Received 6,320 Likes
The following 2 users liked this post by Norri:
Joedotcom (08-27-2017),
#34
#35
#36
Hi
cheers
Joe
cheers
Joe
Gotta admit, this is awesome work!
#37
Location: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Hi
cheers
Joe
cheers
Joe
![Icon Imnotworthy](https://www.jaguarforums.com/forum/images/smilies/icon_imnotworthy.gif)
#38
#39
#40
