after market rotors
hi, im in desperate need to replace brakes all around, have an appointment at the local jag dealer tom. (fri feb 10) for oil change, hid bulb change (yes this shop gets it covered anddone no charge by S.E.)ect.and i was quoted $1400 brakes all around not including e brake. so ive looked at some sites andother posts here and im running into the same problem as other have.No one seems to know the difference btween the 300mm rotorson the 4.2land 362mm on the R. Has anyone succesfully found and installed a set of aftermarket rotors/pads?
Well I think you answered your own question, the R rotors are bigger and I doubt they will fit on a non-R S-type, maybe if you change the caliper along withit. When shopping aftermarket make sure it excludes R models. If I'm wrong someone will chime in and correct me.....(clears throat)FTJ....
thanks for the reply super jag, I do have an r model but it seems all these on line stores and autoparts stores ive been to have the
same part number for both v8 models. there is a HUGE difference in size for my Rand and the standard v8 icant seem to find any company who makes a 360mm rotor. brembo or otherwise.
Front: C2C8355 and Rear: C2C8356 . I found them new for $565 shipped (for all 4).
http://www.trademotion.com/partlocat...?siteid=214626
http://britishparts.co.uk/
The brakes on the S-Type R and XJR and I would even say XKR up to 06, were made for Jaguar by Brembo. Hence the cost involved in replacing them.
Sorry I was late in getting to this post, however: There is a 300mm rotor, 320mm rotor (sport package) and 363mm for the R. You cannot interchange them.
I am glad you found a cheaper version. Not too sure about the ceramic pads though. let me know if they squeel once you get some miles on them.
The R brakes are easy to replace also. However, when you go to do the rears, there are some precautions to take so as to not set the Park brake fault light.
When you get there, let me know and I will help you.
ORIGINAL: styper526
Wow thanks for the help super jag! saved me alot of money
got ceramic pads to go along with the new rotors from tire rack, hopefully keep the dust to a minimum and they were about $50.00 a set cheaper.
I ordered all of my stuff from discountbrakes.com for my 2003 S-type R
It was tricky figureing out all of the correct part numbers because they tend to mix up all different size parts for one app. This is what I ended up with.
Part #: CE100.09710
Brake Pad Set Brake Pad Set S-Type
Centric
Qty: 1.00
Price: $ 35.37
Part #: E35DP31462C
EBC
Qty: 1.00
Price: $ 108.79
Part #: CE106.05921
Centric
Qty: 1.00
Price: $ 41.82
Part #: CE120.20018
Brake Disc Brake Disc S-Type
Centric
Qty: 2.00
Price: $ 87.77
Part #: CE120.20019
Centric
Qty: 2.00
Price: $ 77.49
Part #: CE100.09710
Centric
Qty: 1.00
Price: $ 35.37
Part #: E35DP31462C
EBC
Qty: 1.00
Price: $ 108.79
Part #: CE106.05921
Centric
Qty: 1.00
Price: $ 41.82
Part #: CE120.20018
Centric
Qty: 2.00
Price: $ 87.77
Part #: CE120.20019
Centric
Qty: 2.00
Price: $ 77.49
