AFTERMARKET stereo
Guest
Posts: n/a
Well hello im new to the forums and had a question on aftermarket radio, im thinking of replacing the factory radio on my y2k stype i did the reserach and im going to have to rewire to set it up im replacing it with a 7" touchscreen stereo...anyone know where i can find the face plate for this or do i need to make my own? thanks a bunch
No you don't have to go custom- if I'm not mistaken as long as your sterio is prior to 2002 ish- a double din will fit in place without much modification. If you DO need to order the faceplate- Metra makes a dash kit for the S Type. I have an '03 S Type with a 7 inch Kenwood DNX7120, and JL Audio 12W7 with JL Audio 500/1 amp. Good luck with your mods!
Not too long- shouldn't be longer than an hour or two as long as you have everything in hand and/or have power tools. I think it took them about an hour to an hour and a half in the shop when I got mine done, and it took them a little longer because my "03 S Type" apparently didn't run off of the same dash kit as the "03 S Type" dash kit I ordered from the UK. Mine came in as a solid grey plastic piece and my dash is black. It didn't take too much manipulation to work but IMO it didn't come out as flush as I'd hoped. I have plans to go back and get a custom faceplate made when I have free time from school.
Are there any web sites which show a diagram series of how to penetrate in behind the radio to remove the old, exchange the connectors and replace with the new ?
If you replace a cassette radio with something with GPS and Bluetooth and maybe even TV, you might have new connectors to route into that space for antennae and brake signal.
