air bag light
air bag light
hi, can anyone point me to where i can find information about the air bag system 2004 V8
i have a manual but i can’t find anything about it
i want to find the wiring at the front and the Sencers
this vehicle has been involved in an accident and something is wrong with the air bag system,
the bag light flashes three times, pauses, then flashes three more times
thanks
thanks
GIYF = Google is your friend...:
http://jagrepair.com/images/AutoRepa...cal-2005on.pdf
This is the Guide for VIN N13089 onwards. My '04 and '05 S-Type both fall into this category.
I assume this guide also covers V8.
But if that is not your guide, then maybe this is:
http://jagrepair.com/images/Electric...al%20Guide.pdf
Maybe this helps:
https://www.jaguarforum.com/threads/...ht-code.78862/
from that I read that your three flashed followed by 3 flashes means airbag code 33
And for airbag code 33:
https://airbagcode.com/jaguar-concept/33
Not sure, if that helps, but maybe it brings you one step closer...
wow, thats great
this car has been in a accident and is a repairable write off,
i bough it at an auction, not knowing what i was doing, i couldn't see where it was damaged and thought it must have been stolen and the insurance company didnt want to get involved in fixing the warning lights, replacing the damaged tires, missing spare wheel etc
i have been looking for the position of the front airbag sensors, i found some information, but it only showed one sensor at the front
the information you have given me is a great help
thanks
thanks
This is what I just found:
https://www.fixya.com/cars/t6977258-..._diagram_front
So if I read this correctly, there is one sensor in the front (centre) and 2 on at least one side...
PS: I am confused now, if part 4 or part 1 is the sensor:
https://parts.jaguarlandroverclassic...ag-sensor.html
On Fords, the airbag light blinks indicate the error code.
3 blinks, a pause, then 3 more blinks indicates airbag error 33.
Code 33 commonly indicates a fault with the driver side belt pretensioner circuit. This could be caused by wiring or more commonly, the tensioner itself. The code is thrown by the Restraints Control Module (RCM) which checks the pretensioners circuit at each ignition cycle.
Be aware, airbag codes are not standardized across all models. Code 33 typically indicates an issue with the tensioner, but it is not guaranteed.***
See posts below, where some X-Type owners were prompted with a code 33.
https://www.jaguarforums.com/forum/x-type-x400-14/airbag-light-flash-code-33-a-126467/
https://www.jaguarforums.com/forum/x-type-x400-14/airbag-code-33-diy-repair-76060/
*** Airbag codes have been updated over time as new generations of SRS systems were created. For example, some 1997 Ford Rangers do not have seat belt pretensioners or a passenger side airbag. Code 33 on this model is noted as a fault with the passenger side airbag. In reality, there is a connector and resistor behind the passenger side faux air bag cover, which when dirty or disconnected, can throw the error code. This was done as a cost cutting measure, allowing FoMoCo to use the same SRS control module across several models both with and without a passenger airbag.
