Air conditioner blowing hot
This has been discussed at length at this forum I had the problem last summer and just kept the air control on manual at 61 degrees F and adjusted the temp useing fan speed. This year I decided to get it fixed with a new dual air control valve ($325 at the dealer and $189 on line) Before doing so, I, for some reason, tapped on the metal part of the control valve with a small wrench and wiggled the electrical conection with my fingers. Guess what, for the last two weeks it works perfectly. I have no faith this will be a lasting fix, but at least I know the problem for sure. Regards, Don
It happened to me as well. My DCCV valve went south in the dead of winter luckily and it also took out my climate control module. Luckily they were both replaced under warranty. If you do fry your CCM you may be able to repair it. There is an article about the procedure in this forum. You might try the fix noted in this post.
https://www.jaguarforums.com/forum/s...-2003-a-36719/
Mike
Mike
OkieTim
09-08-2015 04:48 PM
