Air conditioning motor clutch not kicking in
Hiya, I have a 1999 v6 3.0l auto s-type
The air con doesn't work,
I have checked fuses and the control panel seems ok.
The clutch isn't kicking in when A/C is turned on
but if I run a live wire direct to it it does kick in,
However even with this direct wire with the clutch activated I stil don't get cold air even when I left it running for a while.
Do I have 2 seperate problems?
Does the A/C fluid need filling up before the clutch will kick in,
I have also had a battery drain problem recently that I think I have sorted, don't know if this has anything to do with it.
Any help or advice will be greatly appreciated,
Thanks, Bill
Thanks, Bill
mrblockpaving (08-21-2011)
Yes. You need adequate refrigerant or else the clutch won't engage. There is a pressure sensor on the low side that checks to prevent you from engaging the compressor without fluid in the system. This is a safety feature to prevent from killing the compressor by running it dry.
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
