Air Flow/Pressure issue
I have a 2006, V6 Jaguar S-Type (if that isn't enough information on the car model, please let me know) with the CEL on, which is throwing the following codes:
thanks, pxhayes
P0491 - Stored Error(Mode 3)
Secondary Air Injection System: Bank 1: Insufficient Flow
P0492 - Stored Error(Mode 3)
Secondary Air Injection System: Bank 2: Insufficient Flow
P2432 - Stored Error(Mode 3)
Sec. Air Inj. Sys. Air Flow/Pressure Sens Bank 1 Circuit: Low
P2431 - Stored Error(Mode 3)
Sec. Air Inj. Sys. Air Flow/Pressure Sens Bank 1 Circuit: Range/Performance
Does anyone have any idea as to what conditions might be cause these codes? Other than the CEL being on, the car doesn't seem to have any problems and runs and drives fine.Secondary Air Injection System: Bank 1: Insufficient Flow
thanks, pxhayes
Welcome to the forum.
1st) You really need to follow forum protocol and go to the "New Member" section and introduce yourself. By doing so you will be upgraded to full membership and be able to have more access to the site.
2nd) Please add the vehicle details that you have posted into your signature. Go to top left of any site page and look for "User CP" then navigate to "edit signature". Help us help you!
Funny enough, alldatadiy doesn't have one of those Jag specific codes available, HHHmm
Look here: https://www.jaguarforums.com/forum/x...tb00139-31956/
Edit: another one: https://www.jaguarforums.com/forum/s...ir-pump-43834/
I’m sorry. I had added that information to the “vehicle info” field in my profile which I thought would also add it to my signature — but it didn’t. It is now fixed. Funny enough, alldatadiy doesn't have one of those Jag specific codes available, HHHmm
From what I’ve been reading here, they’re rare error codes. Given their rareness I thought I should maybe ask the hive mind for its collective wisdom in addition to mining the boards for data.Thanks for the information!
— PXH
My apologies, I’m a noob at this. I’m starting my gearhead phase about three decades later than all the other guys in my father’s family.
Thank you: I was grepping search terms across JTIS's service manual files this afternoon without much luck. I suppose that I'll have to check out this TOPIx thing….
I found a site with some notes on one of my four error codes (it didn't have anything for the other three).
** Generic OBD Error Code Details for P0492
** Secondary Air Injection System Insufficient Flow
What does this mean?
OBD Code P0492 refers to
Symptoms
Possible symptoms of OBD code P0492
- Engine Light ON (or Service Engine Soon Warning Light)
Causes
Possible causes of OBD code P0492
- Intake leak
- Damaged AIR system components
- Faulty AIR Solenoid Valve
- Faulty AIR system relay
Possible Solutions
[null in original]
source :— Jaguar P0492 OBD/DLC Error Code - Secondary Air Injection System Insufficient Flow
Symptoms
Causes
- Intake leak
Possible Solutions
[null in original]
But here is a simple check that may help out:
https://www.jaguarforums.com/forum/s...ck-pics-49214/
It does sound like this might just be the culprit. Worth a shot.
Sorry for disappearing. I made a trip to Chicago for a seminar on autism and to visit some friends. This also means that I haven't had time to look under the car yet. However, I did drive it a lot, often with my laptop hooked up to the OBD-II. I didn't learn much from that, but I don't know what to look for either.
Basically, what I did learn is that the car gets about 24 mpg at 75 mph.
99xk8guy
06-05-2023 06:28 AM
rsa760041
23
09-25-2015 01:33 PM
