AJV8 flywheel
>make a new front cross member as my original engine is rear sump and the AJ-V8 is front sump
Ok, gotta ask the question... What the heck are you doing? Are you transferring a Jaguar V8 into another car and if so, why?
Seems almost impossible to me.
Understeer is when you hit the wall with the front of the car
Oversteer is when you hit the wall with the rear of the car
Horsepower is how fast you hit the wall, and
Torque is how far you take the wall with you
I was originally fitting a T5 Volvo engine, but the lack of suitable transmissions is a real problem. Most people doing that swap chop the front off a 960 auto bellhousing and replace the front of a BMW 6 speed bellhousing with it. The ultra rare Volvo RWD 'box for the later engines has a tendency to blow up much beyond 200ft/lbs and I was hoping to make twice that @ 30psi of boost.
Thanks Rick.
I've arranged to pick the car up in early January, but I can show you a photo of a Volvo 240 with an empty engine bay, if you like? And an intercooler designed for a V8 that I'll probably use to replace the chargecooler?
I've got a photo of the XJR too, but it looks just like any other XJR
![Icon Biggrin](https://www.jaguarforums.com/forum/images/smilies/icon_biggrin.gif)
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
#28
#30
#33
#37
#38
Have you been able to test the flywheel yet? I'm really keen to speak to you if possible about the flywheel as I'm at a point with my project (4.4 AJV8 - Ford Capri) where I need to machine the flywheel so I can get the gearbox in for good. I have the S-Type clutch, box and bits etc.
#39
#40
User 42324 (09-01-2020)
