Alignment specs for 00 s type
Greetings, I am looking over Brutals spec sheet and the note about total front toe being set as close to + 26 degrees as possible. Is this note specific for the 03 and up or for the first generation s type? Having replaced the worn bushings I had it aligned and now it pulls to the left and is twitchy, hunting to left and right on our bumpy roads.
cloud hands (05-01-2014)
I replaced the two big ones on the front lower arms and the ones on the rear lowers, total of 6. The big ones with the eccentric (front arms) were easier to replace. I got the bushings from Duezt place on ebay. those rear bushings are 100th of an inch oversized and I had to hog out the control arm with die grinder to get them in. And they were all the same size as in the width of those bushings so I had to shim 2 of them.
Still not sorted out... Tires were not the issue. I ordered new bolts for the front lowercontrol arm because the eccentric washers were missing on my car so the tech can make easy adjustments when alignment is performed. After i instal them I will take it to another shop for alignment and see what happens. The new bushings i installed on the front lower control arms (the big ones) are suspect. When it was on the lift gettting tires I checked those bushings with a pry bar and one was very easy to move [and they move quite a a lot] while the other side one was just a little less easy to move. I had their alignment guy feel that with the bar, he said "if you had not told me they were just replaced I would have thought them to be worn out"! It could be them and I will have to get a 3rd alignment done if I change them out again...
KarimPA
09-03-2015 07:32 PM
