All Lights Blinking on and off
Need help with blinking lights. Lights set on auto. While driving, all lights, (dash, headlights, tail lights) flash on and off very quickly. Only does it for a few moments, (about a minute duration). During a 75 mile trip it happend probably 5 separate times. Engine showed no loss of power (by feel or rpm) during these times. Any thoughts?
jagnewby (02-18-2013)
jagnewby (02-19-2013)
Need help with blinking lights. Lights set on auto. While driving, all lights, (dash, headlights, tail lights) flash on and off very quickly. Only does it for a few moments, (about a minute duration). During a 75 mile trip it happened probably 5 separate times. Engine showed no loss of power (by feel or rpm) during these times. Any thoughts?
Haven't had a chance to check on other settings. No water or detectable moisture in trunk. Battery connections and wires look good, clean and tight.
Did notice that headlights were ON in bright lighted conditions (daylight) while set on auto. Need to mention also that recently, (couple of weeks ago), battery drained low enough, after getting windows tinted, that car needed a boost to start. I did, however, get all the low voltage messages cleared throughout the system afterward. Have not put a good recharge on battery since.
It's not too hard to change the MFS but I am just guessing? Do you have the JTIS? I have not changed one on the S Type and the last one I did change was on a 1993 Ford. The one on the S Type is more complicated but looks like it's installed the same way.
Remove the plastic shroud around the steering column and you should be able to see what to unbolt.
jagnewby (02-23-2013)
neruda
10-18-2015 01:19 PM
rsa760041
23
09-25-2015 01:33 PM
