AllData subscription for '02 S-type
How good are the pictures and information available through an AllData subscription for the S-type?
Are they just generic or are they really S-type specific?
Could you show me what they say for intake manifold removal and reinstall?
If they are car specific, I will probably purchase a subscription. Thanks.
I very rarely service X and S Types, and am not too familiar with the 3.0 engine. I replaced plugs on a 3.0 X Type, and browsed the following information first which I found helpful. It is a blog entry published by Steve Hannes: he has been a contributor to this forum in the past as well as a participant in several others I browse. The link is provided without his permission, but his blog is a public one which appears on Google search so I don't think I'm opening any locked doors. Hope this helps you, it's all I got.
http://jagmotorproject.blogspot.com/...ing-plugs.html
I have the subscrition for an 05 and many other vehicles...alldatadiy is worth the money. BUT you aslo can go to autozone.com join for free and get the procedure for free as well. I compare both before doing any procedures. They vary abit but very helpful.
As far as replacing what you specified its not a hard job at all. The most difficult thing is, there is a vacuum hose at the rear of the intake that I found was tricky to remove! You will need to get the (6) UPPER intake gaskets, replace the (2) IMT O-Rings as well and if your close to or over 100,000 miles replace the spark plugs.
Rick
May I ask why you are replacing the intake gaskets?
Rick
Rick
Rick
It seems from reading that the P0420 can be a bad Cat or too much fuel, of even oil getting to the Cat. Since I have only had the car for about 14K miles, I am pretty certain the plugs are new. I am not certain how hard the previous owner drove the car. But I had to replace a transmission spring shortly after I cought it, so I assume the engine was taken full advantage of. The air filter looked like it had never been charged, as did the cabin filter. Both were solid black.
Also the fuel economy is getting worse. We are getting about 20-23 mpg now.
I do not have a Jag dealer within 80-90 miles of me. That is why I wondered if the gaskets from a Lincoln LS 3.0L might work... No one near seems to be able to source parts for the Jag 3.0L.
Rick. Thanks for any advice you might be able to give.
X308XJR
05-20-2019 06:50 PM
