Another headlight question
try swapping bulbs around between left and ride sides. If the suspected bulb works then its the ballast, or if the bulb doesn't work, then its the bulb. Just in case, make sure you use the bulb thats already works on the suspected ballast, this way you can make sure its not just a loose connection.
