Another window regulator failure
Old 08-13-2012 | 08:34 PM
VMV's Avatar
VMV
Default Another window regulator failure
Hi all, I haven't posted in a while but my 2000 3L SE is still going strong with 98k miles on it. It was very hot here today. I took my dog to the vet.
After the appointment, I did the trick with opening all the windows by holding down the unlock button on my remote. When I began driving off and raising the windows to run the AC I found that the L side passenger window would not raise and made the ominous regulator failure sound.
This will be the 6th or 7 window regular failure I've had on the car. It's one of the few negatives with the S-type. Fortunately with all this experience, I can repair it very quickly and at relatively low cost.
I was wondering if this a lot of failures compared to others.
ALso I was wondering if this was another issue that was resolved in the later generations of the S-type.
all the best VMV
Old 08-13-2012 | 09:07 PM
bfsgross's Avatar
Welcome back VMW. To the best of my knowledge, my 03 STR hasn't experienced a failed window regulator. Though you've repaired window regulators, please don't take offence if I ask if perhaps there was a misstep in installation. Is this the first or second regulator to fail for this particular window? R U sure the regulator failed, not the protection circuit. It was pretty hot when it failed.
Old 08-13-2012 | 09:35 PM
It does seem like a lot of failures.
Opening and closing the doors with the window open doesn't help.
I suppose you know already that you can use the LS part for your car.
Old 08-13-2012 | 10:30 PM
clubairth1's Avatar
The regulator problem is another mainly a 1st generation (1999-2002) problem. Be sure and use the Lincoln LS part from Amazon. It's about the cheapest and comes with the motor too so easier to change out.
The second gen cars do lose a regulator now and again but much less often.
Old 08-14-2012 | 08:54 AM
abonano's Avatar
Originally Posted by VMV
Hi all, I haven't posted in a while but my 2000 3L SE is still going strong with 98k miles on it. It was very hot here today. I took my dog to the vet. After the appointment, I did the trick with opening all the windows by holding down the unlock button on my remote. When I began driving off and raising the windows to run the AC I found that the L side passenger window would not raise and made the ominous regulator failure sound. This will be the 6th or 7 window regular failure I've had on the car. It's one of the few negatives with the S-type. Fortunately with all this experience, I can repair it very quickly and at relatively low cost.
I was wondering if this a lot of failures compared to others. ALso I was wondering if this was another issue that was resolved in the later generations of the S-type.
all the best VMV
Did you elongate one of the mounting holes for the window motor?
I've seen many DIY'ers elongate the wrong hole for one of the rail assemblies or worse yet - squeezing those LS regulators into the original mounting holes leaving tension in the window rails - this could be the cause of the repeated failures.
Just my $0.02
The following 2 users liked this post by abonano:
bfsgross (08-14-2012), space0matic (08-16-2012)
Old 08-14-2012 | 09:37 AM
Jon89's Avatar
You may hold the Guiness Book of World Records for the number of failed regulators on any car less than 15 years old. As others have said, the later-model S-Type regulators have been improved and do not seem to fail as often as the early-model S-Type regulators do....
Old 08-14-2012 | 09:43 AM
Gus's Avatar
Gus
I replaced all 4 window regulators in my car and the drivers side twice. The Lincoln LS regulators will fit the front windows and I heard of the elongating of the hole but I never did that. It seems to me that the alignment with the window is imperative for longevity of the regulator. I also noticed that the window when closed has an extremely tight fit that may also contribute to the failures. FYI I replaced all windows at around 66k mi and the drivers at around 80k mi and I now have 98k mi on the car and they are working just fine. I will provide a link for window regulator replacement.
Link: JagRepair.com - Jaguar Repair Information Resource
I hope this helps.
The following 2 users liked this post by Gus:
Old 08-15-2012 | 11:21 AM
VMV's Avatar
VMV
Talking
Thanks for all the great suggestions! I had almost forgotten what a great forum this is.
I took the door panel off yesterday and removed the regulator. As always in the previous failures the plastic clip that secures the cables had fractured. This is the first failure for the L rear window. Probably because I don't open it very often.
In checking Ebay for inexpensive window regulators I was pleasantly suprised to find a vendor selling just the replacement plastic clips. I ordered one and will receive it in a few days. Definitely much cheaper that replacing the whole regulator.
The following 2 users liked this post by VMV:
Norri (08-15-2012), space0matic (08-16-2012)
Old 08-15-2012 | 11:55 PM
clubairth1's Avatar
Yes that is a fairly new development. Please report back on how that works out. It's a bunch cheaper!
Old 08-20-2012 | 11:55 AM
VMV's Avatar
VMV
Default replacement regulator clip
i received the replacement plastic clip a few days a go and installed it on my window regulator yesterday.
A few problems arose: It was difficult to get the cable ends into the new clip and take up the slack. I ended up having to force and lever the cable back onto its reel , then lever it back into place on the lower guide.
Not a particularly easy job. I was concerned about the clip snapping onto the metal channel of the regulator without breaking but it was fairly easy after I inserted the longer guide into the metal channel, then sqeezed the channel lip inward and pressed the other plastic guide down into place.
After all this I found that the vendor sent me was the wrong clip ( R side rear instead of L side rear ) as the hole in the clip did not line up with the slot in the channel where one would re-install the plactic pin that secure the window.
I jury-rigged it so that I could use it for the short term but will contact the vendor about this problem.
While it is cheaper than replacing the whole regulator, it was much harder work to do so.
Also it raises doubts about the vendor if they can't send the correct part.
Norri (08-20-2012)
Old 08-20-2012 | 01:56 PM
tbird6's Avatar
Thanks! You are the first person I know who has tried this. Since the entire regulator is only about $70. I think I will keep replacing the entire unit.
Old 08-20-2012 | 05:44 PM
bfsgross's Avatar
VMV, your experience with the window regulator, despite recieving the incorrect clip to retain the cable, is still valuable for anyone taking this route.
Old 10-21-2012 | 02:54 PM
nickthap's Avatar
I just did my second regulator replacement on my 2000 with 93k--first one was the passenger front, this one was the driver's front.
In both cases it was the motor.
As far as the how the pins align to the door frame holes, the first time we lined up and inserted the three posts to the top holes in the foor frame, and had a heck of a time aligning the bottom ones. We really had to do some wrenching to get it to fit.
This time around I lined up the bottom holes first, screwed in the one bolt (in the middle near the motor--the replacement regulator has a screwhole here instead of post), then popped the three top ones in easy as pie--no wrenching need. It's a snug fit, but then I'd imagine the door probably changes shape fractions of an inch after 12+years.
Old 10-21-2012 | 03:11 PM
abonano's Avatar
Hi Nick - Refer to post #5
Old 10-21-2012 | 05:48 PM
bfsgross's Avatar
Hmmm? Wonder if nick is "on" regarding warpage of door over time? Anyone else have thoughts?
Old 10-21-2012 | 06:19 PM
Gus's Avatar
Gus
When installing the 2 rear window regulators the only problem I had was the removal and install of the plastic pin used to attach the window to the regulator. Both regulators bolted up as easily as the removal. As a side note I got them both online using Amazon. I am wondering if I missed something.
Old 07-06-2020 | 10:02 PM
FarmerJohn's Avatar
The left rear window just stop working on my 2000 S-type. I removed the door panel and it appears the cables came out of the clips or more likely the clips broke from reading the above posts. I will order the clips and attempt to rebuild.
Old 07-07-2020 | 11:59 AM
clubairth1's Avatar
I never replace the clips. It's way too easy and fast to just replace the entire regulator. It's a known failure point.
Have you ever done one?
Many instructions on this forum too if needed.
Old 07-07-2020 | 06:54 PM
FarmerJohn's Avatar
Not on a Jag before but many others. Found a video on youtube showing how to replace clip and install cables (
). Doesn't look too bad, part was only $7 so I will try this 1st.
kr98664 (07-08-2020)
Old 07-22-2020 | 08:56 PM
FarmerJohn's Avatar
Well I received the clip but it was the wrong one. Must had been the same packaging guy that sent member VMV his clip. They sent the correct one in a timely manor so I thought it was correct. Install it to rail and assy in the car but when I tried to get it to align into the inspection window of the rail I could not see the hole in the clip or the hole in the window. So I could not install the barrel nut to the window. I spent too much time on it so I will order a complete window regulator assy. Attached is a pdf of some pitfalls of replacing the plastic clip.
The following 2 users liked this post by FarmerJohn:
joycesjag (07-23-2020), kr98664 (07-22-2020)
Moghut
10-01-2015 02:55 AM
Jaguar Forums Editor
Jaguar Press release
09-28-2015 06:18 PM
bydand
09-28-2015 10:47 AM
bydand
09-27-2015 01:00 PM
Quick Reply: Another window regulator failure
