Anti Hijack "Possible Theft"
Hi all, new to the forum. I have a Jag (2000 S-Type 3.0 V6) ... was in an accident and had to replace dash and steering wheel after airbags blew up. Replacement dash came with cluster and the garage recklessly fitted the dash with its cluster (instead of retaining the original). End result (even after putting back original cluster): car alarm goes on, light on top of dash rapidly flashes, engine won't even make a sound, diagnosis reads "possible theft" . The steering wheel drops every time the key is placed in the ignition though, so there must be a little recognition. No?! Is there a way of convincing the car that everything is alright... a more manual way of reseting it?!
bigwilattitude (05-28-2017)
Awesome stuff. The garage did mention such a 'prescription', and are currently working on it. Did not trust them enough to do it right the second time around ...needed an enthusiast's second opinion before giving them a go ahead. For the record, I made so much noise that they are having to call in an official Jaguar dealer, and will be footing the bill.
Does the shop still have the original cluster?
I hope for you this can be repaired as the dealer is most likely to have the needed tool to get it working. With different IP and different odometer readings it is a real mess to fix.
Please post back if you can on the repair. Dealers most likely won't tell you what went on but it's worth a try.
Best wishes for getting back on the road,
Ken
