antifreeze leak
antifreeze leak
Hi all im new to forum ! great to find some jaquar buddies
here is the problem i have a 03 stypeR with 120k on it has a antifreeze leak after it warms up and has been driving for a while like 30 min it leaks out of the top of the motor intake area and then runs out on rear of motor down back side of motor to road ,
it looks like the leak under supercharger in rear or under there somewere
any clues ????
any clues ????
Lots of hoses because of the intercooler plumbing!! I would pressure test the cooling system when cold. Much easier to look for leaks if the engine is not burning hot. Most auto parts stores have a tool loan program. Usually this will include a coolant system pressure tester. I know the local AutoZone does.
Has any cooling system maintenance ever been done? The coolant should be changed every 5 years minimum. Be sure and flush the system thoroughly. Also change your thermostat and degas bottle cap. I would plan on doing all of these when you find the leak.
dealer
i dont have a garage as yet so i got to take it to dealer tommorow am the misses drives it and now we have a rental , just had water pump replaced at a shop they thought it was the problem but no go
**this sucks big time even if i had a pressure tester im sure the leak is related to the intercooler or hos etc no t easy to get to , ilo see how bad the dealer reems me
repaired at rockville md jaguar
Well the dealer repaired the leaking hose under the S/C and all good
It took them a week (I can live with it ) not that great said they had to order parts .
They also replaced EGR valve
1 I now have a driver side window that doesn’t go up automatically anymore
2 rear windows no longer defrosts
3 passenger muffler hangers is separated
Very strange how 3 new problems exist after leaving dealer?
you think you had problems with your dealer, have a look at this thread
http://www.jaguarforum.co.uk/viewtopic.php?f=16&t=27765
kevo
09-08-2015 09:45 AM
antifreeze, back, coolant, cooling, intercooler, inurlforum, jaguar, leak, leaking, motor, plumbing, pressure, supercharger, system, test, xjs
