Any history of transmission module (TCM) going bad? 03 S-type V6
How often has it happened?
If it keeps happening you're most likely looking for a bad connector or chafed wire, but if it's just once then ignore it.
But... always check the battery!!!!!!! A failing battery throws weird codes and you'll swear it's good because it starts the car - worst "proof" imaginable.
What is it?
I just bought the car, battery was partially discharged, I charged it and most codes disappeared. There were probably 20-30 codes from different systems, now about 5-7 left.
Transmission is in limp mode because there is no communication from TCM.
Thanks for all responses. There is a chance just to have electrical problem, not mechanical transmission one. I know it is Ford V6 engine (Ford Contour, Mercury Cougar), hopefully it is Ford transmission.
Wolfy
05-28-2024 08:06 AM
aholbro1
08-05-2021 05:02 AM
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
02jagstype
09-04-2015 08:20 PM
