Anyone see this on the Eaton forum?
What you're looking at there is just an oil-to-water oil cooler. They've been around for a while. I just put one on my race car because I didn't have room for a big enough air-to-oil unit which is what most vehicles have. I don't think anyone has patent rights to those units.
I haven't looked that closely at the killer chiller because I basically don't believe in the design. It will heat-up after long runs so it's only good for bursts at best. That's just fine for many folks needs. It also may have very different coolant flow charcteristics than a simpler air-to-water unit. So a direct copy no.
Bob S.
Bob S.
What has been uncovered is the plate type heat exchanger killerchiller is using. This one you can buy for about $79 (instead the $750 from kincaid, where you buy the idea and some connectors/tubes...).
Here is where you can buy the heat exhanger, and then you can make your own:
http://www.dudadiesel.com/choose_item.php?id=HX1230ST
