Arm rest wont open
I was able to open it by rocking it to and from, while at the same time lifting it. I found that about 2/3rds the way down, there are two spring loaded clips on either side, and appears to be cam driven by a cable attached to the release button. When I lift the button, these don’t move. When I get the opportunity, I’ll remove the arm rest and see if I can repair it.
It is a common issue. The part of the handle that releases the latches inside the armrest breaks. What you have to do is slide a screwdriver between the top of the armrest and the cupholder to release the clasps. At that point I just used some tape and tape them in the "in" position so it doesn't lock anymore.
I managed to pop open the arm rest by pressing in the two clips on the sides. Once open, I found that the cables attached to the unlock button, had slipped out of their respective clips. With a tiny screw driver, I pushed the cables back into place. I’ll see how long this lasts. A replacement from Jaguar is $800. I hope this helps.
Cadillac (09-07-2011)
Guest
Posts: n/a
I have nothing new to share except that I read the threads for this question and found all of them to be VERY helpful. I followed the suggestions and to my amazement, the arm rest that the DEALER said didn't open (I bought the car used and it never opened) came open. I was able to tape the tabs in the open position and alas, I guess we discovered something that even the Jaguar dealer didn't know (yeah right). The only suggestion they had was to replace the console for $1200. So much for faith in a dealership. Thank you so much for sharing your invaluable wealth of knowledge.
RaceDiagnostics
09-13-2015 02:22 AM
