Audio connectivity module and iPhones
Hello,
Guys I installed the ACM in a 03 STR few years ago primarily for the USB port, much more convenient than a CD changer. I also got the first iphone (metal back case) around that time. Everything worked well but i wasn't interested in iphone playback anyway.
I tried plugging in a 3gs with 3.1.2 software and it doesn't even charge (which is all i want), keeps telling me the "accessory was not made for this device" and when i tell it not to use the airplane mode it just repeats the message.
I found a ACM firmware upgrade from dension which i performed and it still does the same thing. http://www.dension.com/jaguar/?agree=0&sc=0
Anybody here with the same problem?
Apple changed the charging pins in the newer Iphone 3G. And ipods produced after sept 2008.
All the previous Ipods / phones could charge using +12v over the firewire pins. OR +5v over the USB pins (both are in the dock connector). Most car audio stuff simply passed +12v over the firewire pins (no need to regulate the voltage down to +5v for usb). This is the case with the ACM as well.
The newer gen ipods / iphones can only charge via +5v over the usb pins, and ingore the +12v present at the firewire pins.
Now, this is enough of an issue that they have made an adapter which takes the +12v from the firewire pins, and makes it +5v over the usb pins so the newer gen phones / ipods can charge.
Here's a link to the adapter:
It just sits between the phone and the cable.
The griffin one is $11.96
http://www.amazon.com/Griffin-Charge.../ref=pd_cp_e_1
The Scosche one is $24.99
http://www.amazon.com/Scosche-passPO.../dp/B001HN6CVA
They also make one with an extension cable on it, so you don't have to have the adapter at the edge of the cable:
Its $30.99
http://www.amazon.com/Peripheral-IS7...ref=pd_sim_e_6
Either one should work fine for the ACM.
Take care,
George
Its $30.99
Take care,
George
For those who don't already have it, here's the webpage with the complete history of updates and changes to the ACM since original issue.
http://www.dension.com/jaguar/index.php?agree=0
Includes info on updating older versions.
Tbird: I'd go with the if it ain't broke, don't fix it theory on that one
trosty
26
12-18-2022 07:40 PM
'05 Gold XJ8L VDP
09-18-2015 08:15 AM
