Auto climate control
Was driving out tonight with the climate control set at 23 degrees on auto.
Then I hear a hissing sound which lasted about 3 seconds like something was purging.
This happened again a couple of minutes later and so on every few minutes.
Any ideas?
Just had a/c serviced and re gassed. Guy said pressure was all good no leaks etc?
Darren.
Any ideas?
Darren.
This noise comes from the cabin. Sounds like the footwell.
Ill re phrase the hissing though. It more sounds like for 3 seconds the HVAC is blowing air at a higher pressure.
Could it be doing this to keep the temperature constant
If it was a leak surely the re gas guy would have picked it up?
Darren, I believe that noise is the AC system "cycling" circulating the freon to keep those seals from drying out - I have the same noise when my climate control is set to "auto" or when the "ac" button is lit - what you can do is press the AC button off and you will notice the hiss noise go away. And BTW - my AC system is fully charged and operational.
So, I don't think you have anything to worry about.
darren-talbot (02-09-2013)
Did you turn the climate control on and turn the A/C off yet? If not, please do so and report back wit yur findings.
rentzoo
11-10-2015 04:56 PM
