autobox selection problem 2000 s type
hi guys
got myself a 2000 s type.
having a problem with the auto box,the gears are fine but selection stick is the problem ill try explain
sometimes i try to start the car in P and no go move it to N starts ok
this is not all the time i might add,i have also noticed that when i go into P the reverse lights stay on but again not all the time if i move the selection lever down and up into P reverse lightgo off and i can then start the car from P its as if the box thinks its in R when infact its in P as when its in p somtimes it has the red indicator in R position i have never seen the red light in p is there anyway i can fix this problem myself an ajustment maybe
as im anewbie here i hope ive posted this in the right place
thanks
jason
thanks
jason
sounds like your shifter cable is strecthed....
you can try and adjust it.....If you take off the center console top. there are 2 jam nuts on the side of the shifter you can adjust those and see if u can make it better...if not the cable must be replace...dont worry its not a big job
if this continues to happen there are some internal tranny modifications that need to be done...but before i went that far i would try a cable
stanjag
08-30-2015 10:35 AM
