Automatic windshield wipers
2005 S-Type 3.0
This is just a question to satisfy my curiosity....
How do they work? I've had mornings when the dew or remains of a storm was all over the windscreen but they didn't turn on. Other times the least drizzle will cause a wipe....or even three or four.
An inquiring mind wants to know.
Eric
Eric
My stock answer is "they don't work very well"....
I'm talking about this feature on ANY car. We don't have it on our S-Type, and I'm glad that we don't. We do have this feature on my wife's 2004 Lexus RX330 AWD, and the operation is just as you describe it - erratic and unpredictable and completely oblivious to the amount of water on the windshield.
I'd much rather make the decision myself as to when to turn the wipers on and off. Plus, it's one less array of costly electronics to screw up and break down....
I also found this:
A new type of wiper system is starting to appear on cars that actually does a good job of detecting the amount of water on the windshield and controlling the wipers. One such system is made by TRW Inc. They use optical sensors to detect the moisture. The sensor is mounted in contact with the inside of the windshield, near the rearview mirror.
The sensor projects infrared light into the windshield at a 45-degree angle. If the glass is dry, most of this light is reflected back into the sensor by the front of the windshield. If water droplets are on the glass, they reflect the light in different directions -- the wetter the glass, the less light makes it back into the sensor.
The electronics and software in the sensor turn on the wipers when the amount of light reflected onto the sensor decreases to a preset level. The software sets the speed of the wipers based on how fast the moisture builds up between wipes. It can operate the wipers at any speed. The system adjusts the speed as often as necessary to match with the rate of moisture accumulation.
I'm not sure which kind our windshields have. It's either the vibration sensor or the light sensor. They have both types.
It's NOT a shock sensor. It is optical like what was described above. You must get the correct windshield replacement because the cars without automatic wipers don't have this "special" spot in the windshield. It's a patch that is centered on the rear view mirror. Without it no automatic wipers!
davidboger
10-01-2015 10:13 AM
2005, automatic, defrosters, jaguar, jaquar, red, replacement, sensor, stype, turn, windshield, wiper, wipers, work, xj8
