aux heater water pump?
this is a link to the cardone part
Cardone Select 5W8005 - Auxiliary Coolant Pump | O'Reilly Auto Parts
I am a professional European wrench, I have an 06 S-type R. The ECM doesn't send ground signal to the control side of the relay (R7 in the engine compartment fues/relay center). I have parused all of the information available to me on AllData, Mitchell 1, and cannot find any description of the conditions for aux. pump opperation. Any ideas where to find this information. If you can piont me To it, I will take it from there. By the way, I've already tested for relay activation at the ECM, I got bupkis. All other Circuit integrity is good ( fuses, connections, wires, pump motor, continuity to the ECM, etc.)
If you mean the aux coolant pump then it's not the "ECM" but the ACCM aka CCM (or RCCM in many cars), I think.
It's an unusual pump to be checking. Did / does the car have a heating problem? It's usually related to the DCCV and that often damages the RCCM.
It's possible you're looking in the wrong places.
chillyphilly
05-19-2020 01:37 PM
Brian BigSkip Skipper
01-27-2016 02:35 AM
