Auxiliary Water Pump
When the heat is off there is no flow to the pump anyway because the coolant is stopped by the DCCV.
Take care,
George
Thanks guys - my car is actually a diesel which I know you don't have over there but it also has the auxiliary coolant pump fitted.
The reason for my interest is that it also has a Webasto fuel burning heater that operates below 5 degC when the engine is running. I am looking into whether it can be made to run without the engine to warm things through before starting on cold mornings.
There would need to be water circulation when it operates and this pump hopefully will do that for me.
George
The Webasto unit is fitted to all S-Type diesels. The diesel engines do not generate the same level of heat as the gas units and in cold weather there simply isn't enough heat to get the engine up to temperature and to warm the cabin.
Many European diesel cars have this system and in some cases (not in the Jag) the unit can be switched by a timer or remote control to heat the car before starting in the morning. The most sophisticated of them work in conjunction with the Climate Control system and switch the internal blowers on too - so the car is toasty warm when you get in!
Hi there,
Sorry to revive an old thread but I've just discovered the auxilliary heater in the manual for the 2.7D and am looking at whether it is usable with the Webasto Thermo Top V in a parking heater configuration. Did you get any further with this?
I've sourced a Land Rover circulation pump, but haven't determined where to install it yet and would rather use the existing pump if possible. If the pump is driven by 12V directly, rather than a PWM signal, then in theory, it should work.
Thanks,
Toby
Thanks,
Toby
Hi there,
The OP goes on to explain his interest is in using the auxiliary pump (which is also fitted to the diesel) to circulate coolant whilst the Webasto heater is running with the engine switched off (parking heater mode).
I've had the heater plugged into a laptop for diagnostics and testing and am now looking to take the next step and run the heater with the engine off (it quickly reaches temperature and switches off without coolant circulating).
JagV8 - you seem to think that my posts are off topic. Surely some useful information might come of a discussion about this pump, how it functions, fails, how to access it to repair/replace it etc. This might even have some relevence for the V8 engine if they share the same part.
Hi there,
Thanks,
Toby
Thanks,
Toby
Unfortunately, I did not manage to crack this problem on my car.
The Webasto unit itself is controlled by the can-bus (is that pwm?) and depends on a signal being sent from the aircon module to the unit when the ambient temperature is less than 5 deg C. To control this manually it is necessary to employ a device that can also produce this signal. Webasto produce a timer unit which can be bought for around £50 which will do this and then at least you could selectively switch the unit at any temperature.
I did not find any more information regarding the circulation pump so did not pursue any further. If you have a circulation pump from a LR and connect this to the Webasto then it should operate with the unit and provide the circulation required so a remote switch or timer could then be used. Getting the interior fans to operate however would be another thing!
I wish you luck with it, i have had to content myself with the abilty to diagnose problems and at least have a working unit that operates as it was designed.
Out of interest, I also have a Rover 75 with a Webasto unit and that was very easy to install a switch in the cabin to operate the unit whenever I choose. (simply needs a -ve supply to the diagnostic pin!)
Howard
Hi Howard,
Thanks for the information, I thought that might have been the case as there was no follow up.
I've got a 1533 timer on order to handle switching the heater on and off - should have that wired up in the next week or two. This will be a major improvement as I think the <5°C operation is a bit on the low side and will probably use it when the temperature is <10°C to reduce the warm up time (and engine wear).
I'm trying to determine whether the auxiliary pump fitted to the diesel is supplied with 12V or a PWM (Pulse Width Modulated) signal. The latter is still 12V but at varying duty cycles (ratio of 'on' to 'off') used to control the speed of the motor. I suspect that it is simply supplied with 12V via a relay (seems that the V8 pump works this way). I was working on my car yesterday and could hear a pump running after I switched the engine off, so perhaps they perform a similar function in both engine configurations. If the pump is simply supplied with 12V then I don't see why a remote channel couldn't be connected to energise the relay when using the heater in parking mode. The other concerns are the configuration of the heater valves and coolant path when the car is 'asleep'.
I purchased my S-type after owning a Rover 75 (where else can you go after 75 ownership!). I fitted a Thermo Top Z to that car and retrofitted a circulation pump and remote control. This was a great system and easy to control by grounding one of the pins as you mentioned. I guess I'm looking to get as close to that setup with the TT-V fitted to the S-type as possible. I never configured the interior fans on the Rover, but found that preheating the coolant on a cold morning and then a quick blast of the fans (with the key in the ignition) was sufficient.
Cheers,
Toby
Cheers,
Toby
Okay, so the electrical guide for the 2004 model states that the auxiliary pump was only fitted to the 4.2L petrol. However, the workshop manual shows the pump in the engine cooling system diagram. I'm pretty sure I can see the pump on my car and it is fitted with relay R7 in the front fuse box (which is designated for the auxiliary pump).
I think I'll have a play with the relay and see if I can get the pump running. If so, I'll test it with the heater running and engine off and see if it produces sufficient coolant flow to prevent the heater from shutting down due to reaching it target temperature.
I believe the V8 aux coolant pump does not run after you switch the engine off so that would be another difference. You should be able to run the 2.7D's pump via a relay. (I'd be worried about battery drain.)
The UK site seemed to say the Webasto is ISO (9141) but I think that may be what was added rather than the way Jag wire it from the factory (the D's elec guide shows it as CAN).
I got the auxiliary pump running tonight by removing the relay (R7) and connnecting a multimeter set to measure current (10A) between the sockets for pin 5 and 3. The pump was drawing ~0.9A which puts the power consumption at ~11W. Webasto specs two types of circulation pump for the Thermo Top V, a 12W version with a flow rate of 500l/h and a 13.9W version with a flow rate of 450l/h. I was unable to find any specs on the auxiliary pump fitted to the diesel but the power consumption seems to be comparable and hopefully the flow rate will be sufficient for a parking heater configuration.
I then fired up the heater and kept the pump running for a couple of minutes, the temperature increased at a steady rate. I left it running till the coolant reached 60°C and then switched the pump off. The heater quickly reached 87°C (and burn out). More testing required but it looks like this may be a viable configuration for a parking heater!
Hi Toby
It seems you are making real progress with this and I will be very interested to hear if you succeed with the timer. The only mention of the auxiliary pump that I could find said it was a new brushless pump "for durability and reliability". No further technical info.
best wishes
Howard
best wishes
Howard
