Auxiliary Water Pump
Quote Yorkie72 Out of interest, I also have a Rover 75 with a Webasto unit and that was very easy to install a switch in the cabin to operate the unit whenever I choose. (simply needs a -ve supply to the diagnostic pin
that would be very handy, as already said 5 degrees is to low, oh for a simple drawing for simple mind???
Hi Toby
It seems you are making real progress with this and I will be very interested to hear if you succeed with the timer. The only mention of the auxiliary pump that I could find said it was a new brushless pump "for durability and reliability". No further technical info.
best wishes
Howard
best wishes
Howard
Yes, I'm slowly getting there with it. The 1533 timer has been delivered, I just need to run the cabling from the heater to the timer which I'm planning to fit in the center console under the armrest for now. When I've tested that, I'll add two relays to control the aux pump. I'm going to aim to fit these behind the climate control panel, splicing in between the ACCM and the aux pump relay. This will avoid having to run any additional cabling into the engine bay.
I'll keep the thread updated as I go.
Cheers,
Toby
A pin and cabling needs to be fitted to one of the heater connectors, which is run back to the timer in the cabin. The timer will also require 12V and ground to function.
StanboyUibigh (12-18-2013)
Ozzy_UK
45
02-19-2019 02:05 PM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
