Axle Bearing Carrier
I have a 2005 S-Type.
My son hit a curb yesterday and broke the not the tie rod but axle bearing carrier. He also destroyed the wheel.
I am looking for the Axle bearing carrier and the only I have found is from parts geek part number W0133-1656055. The part is $620.
Part # the component 2W93-3K186-E
Is there a Ford equivalent? Am I better off finding one in Junk yard and replacing?
Thank you,
Thank you,
Check Ebay. Lots of them listed there. Used ones under $200 can be found. Unless you have Brembo brakes. I believe the official name is "Hub Carrier", but you will find most of them listed under "Rear Spindle" The rear hub carrier should be common to the Lincoln LS or same DEW98 platform Thunderbird. I am pretty sure they are the same for late model Jaguars as well. Check the P/N to be sure. (They have made a few variations with longer arms that hold the Toe rods.)
