Bad O2 Sensor? P1647 Code
With O2 sensors I swap them side to side first. If the code follows then swap the sensor out.
Did you swap the correct side? You are correct P1647 is the LH upstream sensor so it sounds like you did.
That code is for a heater failure in the O2 sensor itself. It's function is to heat the O2 sensor at startup until the exhaust gas can do it. So the code should come on immediately at a cold start. Is that when it happens?
No heater fuse that I know of? But that would be good to check.
The PCM adjusts the heater current from a high of around 6 amps and ramps it down quickly as the exhaust heats the O2 sensor. The heater circuit is only used for just a short time at startup.
Have you measured the resistance between wires on the O2 sensor?
I had to change out one O2 sensor and was able to see the bad one as it measured different from the other side and from the new one I purchased.
Bradley Chambers
39
02-11-2016 10:55 AM
Poet
10-06-2015 09:40 PM
